Need some cam help.
Old Aug 25, 2013 | 10:53 PM
ChEvY mAn 707's Avatar
Default Need some cam help.
So I'll be the first to admit it I don't know the first thing about cams. I'll start off saying I have a 2008 gmc 4x4 vortec max 6.0L, kb racing kit, 76mm turbo. Where do I start to look for a cam, the numbers are Greek to me so I don't get them. Also do I need a special cam for the vvt? Like I said be gentle, I don't know anything about them, thanks for the help guys!
Old Aug 26, 2013 | 06:14 AM
delete the vvt and pm stock48 for one of his cams.
Old Aug 26, 2013 | 06:48 AM
Ok, how would I go about deleteing it?
Old Aug 26, 2013 | 09:14 AM
Vortec350ss's Avatar
You need to replace certain internal parts like your lifters. It's fairly easy... the only pain is that you have to pull the heads to get at them rather than just doing a typical spring swap. The good news is that you will have a much easier time with the springs once the heads are out of the truck.
This will help explain the cam specs you read as greek.
Camshaft Choice - Camshaft Specifications - Guidelines - Hot Rod Magazine
Old Aug 26, 2013 | 07:34 PM
If the truck is just vvt then the lifters are fine...no need to replace , the dod lifters should be replaced.
Old Aug 26, 2013 | 08:34 PM
Camin00's Avatar
Isky triple 212 cam has had good results with over all power band due to the lower duration. Idk if it will work in the vvt setup
I have seen a white rcsb 4X4 gmc run in the 9's with your set up and that cam.
Old Aug 26, 2013 | 08:45 PM
I'm afraid my tranny would puke if I tried running 9's it's still the stock ?4l65e?
Old Aug 27, 2013 | 07:53 AM
Yes it would definitely puke. You would need a very strong 80e for those times.
And I thought the L76 was only DOD, not VVT. That early in the game only the L92 was VVT, right?
Old Aug 27, 2013 | 09:19 AM
I honestly don't know, if not that makes it easier for me to cam it, can anyone confirm that for me?
Old Aug 27, 2013 | 07:01 PM
Blackpanther99's Avatar
9s in the 1/4 mile? Agreed with Vortec350ss.
