need more fuel
I gave up on tracking costs, but this is a serious setup and is not cheap. I would say something this complex and beefy is in the $3000 neighborhood. All those small bits add up quick! But it should behave just like a factory setup. No worries about how much fuel is left in my tank. No fuel cell in the back of the AV which is contiguous with the passenger compartment. Only the factory pump running under most conditions. The surge tank is another Trick piece I had Rick fab for me. It will mount in the spare tire area.
![](http://i114.photobucket.com/albums/n241/TDOC2004/100_3308.jpg)
The MagnaFuel and other pumps mentioned here are primarily external pumps, but I believe I have seen the A1000 mounted intank. The A1000 is only good for 700fwhp on an FI setup and requires a separate controller to prevent overheating if run continuously.
Bosch 044s can be mounted intank. A pair of them might work for you. Your tank will no longer be stock though and you will have to take it easy if the tank gets below 1/3 to 1/4 full.
From what I recall, Mototron 60s are good to around 800FWHP(FI, 60psi base pressure) if you want to keep them down to a maximum duty cycle where they remain reliable. Siemens now offers 80lb injectors in the same style and they are also High-Z, no peak and hold driver box required.
edit: $3000 doesn't include the 95lb low-Z injectors and peak and hold drivers for them. Tack on another $700 - $800.
If its only going to be at that power level for a few runs on the dyno couldn't you get by with twin intank 255's and a couple of meth nozzles? I just did twin intanks on my truck and it dropped my IDC's by 35% to around 60% with only one of my meth injectors hooked up.
You can get a walbro 255 inline or intank which ever you prefer. A1000 is a inline pump and supports 800hp FI. modify the fuel bucket and you can have two walbro's 255 intake pumps. One walbro pump supports up to 500hp FI.
any pic of the 255 intank? i know were one of them go but i think you have to cut out the other side of the can. i dont know what it is called but i was told i had to go to make room for the other pump. like i said i dont know a lot abou the names of all this fuel ****...LOL
https://ls1tech.com/forums/fueling-i...ick-cheap.html
Truck Sponsor
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
