need to make my maggie PURR (6L specific)
Old Jun 10, 2010 | 11:45 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by fastnblu
At least I think u have a 4L80E, cause I thought 1500 HDs did. What rear gear?
I'm pretty sure that 4.10 gears were standard in the 1500HD.
Old Jun 11, 2010 | 05:16 PM
justincredible5's Avatar
so i dont need two pumps? why would the kit be designed that way then?, what about two 044s one in tank and one inline just for a little extra
Old Jun 11, 2010 | 05:54 PM
1989k1500's Avatar
Its made that way so you dont have to take the tank out.
Put one in the tank and call it good. Having 18 pumps isnt going to do anything when you dont make enough power to max out one.
Old Jun 11, 2010 | 09:16 PM
SimpleManLance's Avatar
i would do a bosch pump in the tank, long tube headers, intake, pulley, and retune/ custom tune. those should help it purrrrrrr. might want to invest in a fuel pressure gauge first before u spend money on a new pump.
when you look at your radix's snout if there is a spacer inbetween the snout and the blower it is the 122. i also dont think the 112's have a radix sticker on the side of the blower like the 122's
Old Jun 12, 2010 | 12:50 AM
1989k1500's Avatar
Thde 112s have a little space in between the front cover and the case. Unless Im not understanding what youyr saying.
Old Jun 12, 2010 | 08:37 AM
is there a spot on the fuel rail you can tie into and run a guage into the truck to see what the pressure is?
Old Jun 12, 2010 | 09:08 AM
ya i guess i am wrong. the 112 does have a spacer.
Old Jun 12, 2010 | 12:33 PM
1989k1500's Avatar
Ya, I think you can run it off that spot where the black cover is in the picture Lance just posted. You'd have to take the core out of the schrader valve and then you should be able to get it there.
Someone correct me if Im wrong.
I knew because my friend got a polished 112 and that spacer wasnt polished, so it really stuck out. lol
Old Jun 12, 2010 | 02:33 PM
Yes, this is correct.
Old Jun 12, 2010 | 07:56 PM
fastnblu's Avatar
Plus, 18 pumps would be a plumbing nightmare.
Not to mention, add a lot of weight.
Roger, I thought 3.73 was std. gear in 1500HD, & 4.10 was optional? Or was it 4.10 & the 4.56 was opt.'l? My sis-law had 1, but she got rid of that thirsty pig. Back then, IIRC, I checked just can't remember.
Lance, that Radix pic is pretty sweet in post #17!
