Need help with turbo installation
Old Oct 20, 2010 | 04:02 PM
fredbear's Avatar
Registered User
Default Need help with turbo installation
I've got a 2003 chevy silverado with a 5.3 litre v8. I really want to install a turbo on it and I have a turbo off of 99 cummins. I dont want to buy a remote mounted turbo although I like them since I already have a turbo is there any way to buy enough parts to make it work without changing much?
Old Oct 20, 2010 | 04:40 PM
Beatdown Z's Avatar
Laid Back
That turbo won't work too well on your 5.3...
Old Oct 20, 2010 | 05:03 PM
Ender06's Avatar
Its possible, but not really woth it. A TURBO is just 1 piece of a bunch of stuff to actually run a turbo in a vehicle. U need a tune, injectors, pipe, oil lines, wastegate, BOV, intercooler, pipes...prob more than that but I cant think of right now. All that would probably cost twice as much as 2 used cummins turbos honestly. I seen a guy somewhere put a D-max turbo as a rear mount, said it worked very well but had to lock the variable veins in place. U could try it but to what succes you have IDK
Old Oct 20, 2010 | 05:31 PM
mmarlow21's Avatar
i used a turbo from a dt 466 international harvester which is alot bigger then the cummins its not the perfect turbo for your app but i used mine on a 350 chev worked great no tune stock injectors just keep the boost down mount the turbo up front easier to get oil to and have plenty of oil drain back i built my own headers but they have some out there to buy and get a air to water intercooler my intake temps got high the air to air cooler didnt cut it
Old Oct 20, 2010 | 10:36 PM
fredbear's Avatar
Registered User
Okay I probably should've clarified a little more but I'm a newbie to the forums..I have the pipes and wastegate and BOV and tune and oil lines..i'm not doing injectors because a guy did a similar project and left everything stock except for the exhaust, intake, and tune....I'm looking at 7-8 psi for boost...I was seeing what you guys would think will be my biggest problem..not going for a monster horsepower rig just something different
Old Oct 20, 2010 | 10:49 PM
kbracing96's Avatar
You'll need injectors unless you limit your rpm to about 4000. The stock ones are only 24lbs pr/hr.
Old Oct 20, 2010 | 10:53 PM
viciousknid's Avatar
Where's the Beef?
+1 on needing injectors. Mine are already maxed out on a mild cam and tune.
kbracing96's Avatar
I guess you could use a Procharger FMU, but these truck already run a base of 58psi fuel pressure and pumping it up that high with a 12-1 FMU might not be the best...
Old Oct 21, 2010 | 11:00 AM
fredbear's Avatar
Registered User
alright guys i appreciate the input i'll get back to you in a couple weeks when the project is done tell you how it turned out
Choda
Jan 22, 2026 02:03 PM
LCHEE
Oct 24, 2020 04:10 PM
lxcoupe
Jul 21, 2015 02:12 AM
black6spdz
Jul 16, 2015 01:32 AM
