Need help finishing LSA install PLEASE
Old Dec 22, 2018 | 05:02 PM
Medic/Z28's Avatar
Default Need help finishing LSA install PLEASE
I installed an LSA SC kit on my 08 Denali last Tuesday. I'm stuck and here are the issues i need help with. It's been a pain in the butt getting this thing done.
MAP sensor does not plug up. I received an "adapter" for it but it doesn't plug up either.
Heat Exchanger Bracket. I can't seem to figure out how to make a bracket for the heat exchanger. I don't weld.
Still haven't figure out a belt size yet. Not a clue...
IAT. Am i cutting beige and beige/blk wire to connect to pigtail for the LSA lid? These wires come from the 5 wire harness for the MAF. So am I t-tapping these 2 wires or cutting them off the harness?
Need a source from the fuse box for heat exchanger pump. Where do I get this from?
I researched but the data online is either vague or they don't have enough pictures to see what they're talking about. Thanks for your time.
Old Dec 22, 2018 | 06:40 PM
musclecity85's Avatar
For heat exchanger brackets you can make some
out of some flat stock you can get from Lowe’s. It might cost about $15 and get some self tapping screws. Any ignition source will work. You can use a relay and tap into the bcm for ignition power. The green plug should be a violet wire I believe I’d have to check, then grab ground, and 12v from the bcm at the black connector should be a red/blue wire. Get the zr1 map sensor it will bolt in. You might have to repin the wires. For the iat sensor if you have one. The wires don’t matter it’s a loop. Cut the two wires from the maf sensor and extend them to the iat sensor. I’d have to check back, it was a thread about it somewhere.
Old Dec 22, 2018 | 10:14 PM
I don't have the wiring colors on me for your year truck, However Google Maf break out wiring and you will see. In the newer tucks there is a built in map in the maf and it shares the signal ref wire so you can't cut that one. I agree just re pin to you connector.
Old Dec 25, 2018 | 09:04 PM
Medic/Z28's Avatar
Thanks for your responses guys. I'll get back on this tomorrow .
Old Jan 7, 2019 | 08:37 PM
Medic/Z28's Avatar
Got it all finished. Brackets for heat exchanger, MAP sensor adapter, IAT wires, Bosch electric water pump and plumbing. Now does anyone know who rents trailers to haul my truck to Houston to dyno shop?
Old Jan 8, 2019 | 05:51 AM
trxmxzx's Avatar
13 Second Truck Club
U-haul
Old Jan 8, 2019 | 09:54 AM
Medic/Z28's Avatar
I don't think it will fit a crewcab truck. Will it?
Old Jan 8, 2019 | 10:25 AM
kbracing96's Avatar
Check with general rental yards. A lot of them rent trailers for full size too. I know a place on the northside of Houston that rents them. but probably easier to find one in your town.
Old Jan 19, 2019 | 11:10 AM
Medic/Z28's Avatar
Okay so I ended up limping her to Houston at 30 mph on a cold rainy night Wednesday after I got someone to cover my back half at the FD. Thursday morning washed her drove up and down then hit Dyno shop. Tuning went great. Injectors and pump are maxed. Little issues like moving water pump lower, bleeding 3-4CCs of air from heat exchanger and ZL1 lid. Per tuner she made 550/550 @ the wheels give or take 10 horses. She drives great and feels strong and healthy. I would like big better injectors, fuel pump and better water pump for blower. Any tips or ideas?
TwiZtedZ71
Apr 20, 2017 10:21 AM
97gmc
Mar 25, 2008 05:59 PM
whitt1
Aug 25, 2007 09:08 PM
BLASTER
Dec 30, 2005 01:54 AM
