need help
Old Apr 17, 2006 | 06:48 PM
Super68's Avatar
Default need help
i was wondering if anyone could tell me how to turbocharge a carburated engine. i hear that it is posible so i was wondering if anyone could help. also what would i need and where would i get it?
Old Apr 17, 2006 | 07:10 PM
MikeGyver's Avatar
You need to build a box around the carb. The entire carb must be pressurized, and the bowl vents and overflow lines must terminate inside the box. Then pressurize the box with the turbo. Then put on a distributor that the vacuum advance also works as a boost retard. I think.
Old Apr 17, 2006 | 10:02 PM
Super68's Avatar
someone told me that i needed to get a blow through carb but i don't know where to get one. does that sound like something you have heard of?
Old Apr 17, 2006 | 10:24 PM
duwem's Avatar
get ahold of Maximum Boost by Bell, good book on turbos/supers and a chapter that explains carbs with boost applications
Old Apr 18, 2006 | 06:41 AM
ktmrider's Avatar
The book suggested is very good.
A blow-thru carb basically has the throttle and choke linkages sealed and the float bowl isolated from the incoming charge. The seals are there to prevent boost from leaking out and the float bowl from exploding the gaskets under high pressure.
This is a pretty rudimentary explanation, keep digging and researching!
Old Apr 18, 2006 | 11:39 AM
kbracing96's Avatar
Check out turbomustange.com
Theres tons of info and a whole section on building blow though carb setups.
Old Apr 19, 2006 | 03:17 PM
Super68's Avatar
i found a web site that makes blow through carbs that can take up to 26 psi. if anyone is intrested the web site is www.tpcracing.com
Old Apr 19, 2006 | 03:35 PM
dhpro's Avatar
Corky Bell...sveral books out there. Just bot a nice thick on that cover FI & turbo. R/
