Need a better 60ft ?Hydroboost?
Old Sep 30, 2010 | 06:22 AM
slowec's Avatar
Default Need a better 60ft ?Hydroboost?
My truck setup is in my sig. My pipes are wrapped. I finally got to the track and ran a 7.91 with a 1.79 60ft. I don't want a larger converter because this is my DD. I want to leave harder and keep my setup pretty much the way it is. I am considering a small shot off the line or a hydroboost swap. Any STS guys done a Hydo swap? I would LOVE to leave on a few psi!
I did search because I know its been covered before.
Old Sep 30, 2010 | 07:29 AM
Atomic's Avatar
I have a gauge for that
Are you dead hooking or spinning any at the line?
Old Sep 30, 2010 | 07:34 AM
slowec's Avatar
Dead hook. It stalls to 2500, but no boost is available then. 1.79 on wore out 255 50 16 mt drag radials aint bad, but I gotta leave quicker to play with the n2o crowd.
Old Sep 30, 2010 | 09:15 AM
00buckshot's Avatar
Oh, yea, blame it on us guys with spray, I see how it is now!
Old Sep 30, 2010 | 01:39 PM
kbracing96's Avatar
If you can hold the brakes and full throttle on the line and your not pushing though the brakes, then Hydro boost isn't gonna help.
Old Sep 30, 2010 | 01:57 PM
slowec's Avatar
It pushes through the brakes at part throttle. :-(
Old Sep 30, 2010 | 02:01 PM
black04's Avatar
Have you tried the syty shuffle?
Old Sep 30, 2010 | 02:05 PM
slowec's Avatar
No, will you teach me???
Old Sep 30, 2010 | 02:10 PM
black04's Avatar
When you're at the tree, put it in neutral and rev the motor up while pushing down on the brake as hard as you can. You will feel the brake pedal sink down a little deeper. Then put it in gear and rev it up with your foot still on the brake. I was able to make a little over 7lbs this way and with a regular brake stall i can barely get 1 psi before going through the brakes.
When you rev it in neutral the vacuum increases so you can charge up the brake booster and have stronger brakes.
Old Sep 30, 2010 | 02:54 PM
slowec's Avatar
THANKS for posting that! I will see what I can do. Some boost at the line would be SWEET!!
