Need a better 60ft ?Hydroboost?
Old Sep 30, 2010 | 03:00 PM
slowec's Avatar
Just realized you'd have to be quick cause you'd be doing this after you stage.
Old Sep 30, 2010 | 03:10 PM
black04's Avatar
Yeah hydroboost would be easier and quicker but this works too just takes some practice. I did it my first time last weekend and my reaction time was 10 seconds
Old Sep 30, 2010 | 03:28 PM
xx_ED_xx's Avatar
l o l
Old Sep 30, 2010 | 04:54 PM
TURBHOE's Avatar
i have hydro boost. when i went to 2wd for a few months i could still brake stall to 7 or more psi. but both times i did i broke the left rear axle. so i went back AWD and can still stall to 7 or so psi. launches like that are crazy. i vote hydroboost but i'm bias. oh, and mine is a very very tight 3200 stall. it will only stall to 25-2800 with out boost. once the boost pushes in it goes to a solid 3200.
Old Sep 30, 2010 | 07:38 PM
Toomnymods's Avatar
wtf is hydroboost never heard of it.. i have the same problem at track.. huge top end power but 1.75 60' is about good as i can get when i should be getting low 1.6's
Old Sep 30, 2010 | 07:43 PM
Jermoslin's Avatar
I have a low mile hydrobooster and pump for sale! It should be in the classifies or PM and I'll post pics.
Old Sep 30, 2010 | 07:59 PM
TrickTurbo's Avatar
Truck Sponsor
Hydoboost power brakes but uses your power steering to be the helper,. instead of a vaccum source. Normally 3/4 trucks have this. The bad thing is if the engine dies, there is no 1 or 2 pushes before the pedal gets hard.
Has anyone every installed a check valve in the line.
Old Sep 30, 2010 | 08:15 PM
1BADAZZSS's Avatar
With the sts last year and my hyrdoboost swap I was able to brake boost 10# on the street with street tires and it would hold.
Old Sep 30, 2010 | 09:00 PM
slowec's Avatar
That is BADAZZ
Old Sep 30, 2010 | 09:13 PM
tarinitup's Avatar
9 Second Truck Club
I can build 6psi on footbrake with 91mm using the rev in neutral method but problem is traction. Are you guys hooking these 7-10 psi launches.
