need 255 pump install info asap on 04 rcsb
Old Sep 22, 2007 | 05:53 PM
3stgstocker's Avatar
Default need 255 pump install info asap on 04 rcsb
im installing a 255 walbro intank pump in a 04 rcsb silverado. when i took it apart i see a metal canister that comes from the fuel pump to it then another hose comes out of it and goes to the outlet. do u have to use it or can u run the hose from the pump straight to the tank outlet. let me know if anyone has done 1. im doing it for a freind and need to get him to work tonite. ANY INFO CALL ME ASAP AT 803 707 4780 THANKS CURTIS
Old Sep 22, 2007 | 06:00 PM
03sierraslt's Avatar
That is your fuel filter, yes you need to use it.
Old Sep 22, 2007 | 06:23 PM
to the top any more info
Old Sep 22, 2007 | 09:13 PM
DrX's Avatar
DrX
You don't want to bypass the filter. And you really don't want to bypass the fuel pressure regulator.
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
CammedZ71
Aug 30, 2015 04:17 AM
gtyler04
Jul 28, 2015 06:21 PM
