Nasty stage 3 ???
I'm looking at the Nasty Performance stage 3 fuel kit for my truck. Anyone out there using it?. Don't know if I need the dual fuel pumps yet but thinking I should do the complete fuel sys now with the boost ref reg instead of piece-meal later.
Oh, this is for the forged 370 going in soon and who knows maybe some day an upgrade to a D1......
Its a complete kit and I would do it. Thier fuel kits use the best materials and easy to install, and like you said you will never have to upgrade down the road. I have the Nasty performance stage 3 fbody kit for my truck and love it. Came with everything I needed.
Ditto. Building a strong foundation is always less expensive and less time consuming than trying to go for max power and upgrading inadequate parts or upgrading parts as they break.
Well I'm rethinking that huge price tag on that sys. Started researching over on LS1 website and have a plan. I put a new Walbro 255 in this year so think I will double up with another, run a y block in the tank with maybe a bulkhead fitting inplace of stock feed line -8 fitting and fuel line up to the Professional products #10611 fuel rails and reg., leave the stock return line. Got to find a "Hobbs switch" to control the second pump with a relay and 10 ga wire from the battery. This should do it and save some big $$ too. If anyone can chime in on this I would apreciate it.
It's over on LS1 tech, It's 1600 bucks!!!!! Think I can do it for less than half of that....
http://www.nastyperformance.com/99-06Trucks.html
you can definately build it for less. lonnie ( who makes the wiring harness does do a nice job though. it is set to turn on at 2-3 psi of boost and mine has worked awesome with the dual pumps, maintaining a constant 75 psi @ 15lbs of boost and a 125 wet shot spraying. kept a constant afr so im happy with mine .
wickedRCSB
Oct 10, 2015 09:29 PM
