My Turbo Truck
Old Nov 16, 2015 | 07:33 AM
  #21
Mike1992's Avatar
I did consider other turbo options, but it came down to price in the end and finding a name brand 76mm+ turbo wasn't cheap. The turbonetics was around $800 shipped and a comparable Precision units would run $1000+
The turbo outlet is 3" so a 3" exhaust should be all it needs. This specific turbo uses a very small 68mm turbine (2.67") Which makes for super quick spool
When I ordered the kit I was under the impression the wastegate would be in the crossover pre turbo and dumped to the atmosphere. However, When the kit arrived the gate was to be manifold mounted and recirculated back into the downpipe. I didn't pay extra to have this done.
I'm sure with a larger turbine wheel a larger exhaust would be beneficial. A lot of flow can also be re-routed by simply venting the wastegate to the atmosphere
Old Nov 22, 2015 | 05:30 AM
  #22
smokinlmm's Avatar
Thanks for posting. Im thinking of going with trick myself, sweet truck. Any guesstaments on power?
Old Nov 22, 2015 | 06:41 AM
  #23
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by lxcoupe
Did you consider the Trick proprietary turbo?
Also, how did you end up at the 3" exhaust? Even Trick himself says the 3" would choke a setup like this. I would love to use a 3" on mine as I think it will quiet it down quite a bit and way more muffler choices.
The 3" full exhaust will choke max out power down.
But if your not going for all out its ok.
Simple to add a cut out or increase to a 3.5 or 4.0" full exhaust if wanting more power.
My 4" exhaust has a nice rumble to it. But to quiet it down you can a resonator pipe to it. I hear that changes the tone nicely.
Old Nov 22, 2015 | 09:43 AM
  #24
Mike1992's Avatar
I'd say 400-450hp at the moment.
The exhaust dumps under the cab, with no cat and a large magnaflow straight through muffler
5.3lSilverado
25
Aug 29, 2016 12:48 AM
kyle's v
Oct 4, 2015 12:37 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
Mzay
Jul 6, 2015 11:03 PM
