My truck is off to shop #4
#362
#363
Looks good! I really need to work on mine as I am still using the dryer duct that came with the kit along with some 4" aluminum tubing to my homemade heat shield and open filter. Did you try putting the S&B box on the other side where the battery is? Just wondering it if it would fit there.
btw... get that Trick tank installed.
It cleans up the engine bay dramatically.
#364
#366
ever get the oil leak fixed? i had a few similar problems on mine, first was the rear main seal. too much pressure inside the engine i guess. i removed the pvc valve and just put a tiny k&n filter in the hole on the valve cover. fixed the problem. the other issue i had was with the oil cooler lines that come out of the block above the oil filter. that was replaced and its fine now.
hope you got all the bugs worked out on it by now.
