My truck is off to shop #4
Old May 23, 2008 | 03:15 PM
  #311
MikeGyver's Avatar
Too rich at low VE.
Old May 23, 2008 | 03:17 PM
  #312
MikeGyver's Avatar
As soon as I hit the post button, I remembered you having the same or similar problem before.
Old May 23, 2008 | 05:07 PM
  #313
TG02Z71's Avatar
I know you know this already buttttt..............your truck is cursed.
Old May 25, 2008 | 03:40 PM
  #314
Slowhawk's Avatar
LS1Tech Sponsor
Dan,your truck is so cursed you put 2 company's out of bussiness. TZ and W2W
Old May 25, 2008 | 03:48 PM
  #315
Hawk179's Avatar
W2W is out of business?
R
Old May 25, 2008 | 04:32 PM
  #316
Justin @ EAD Performance's Avatar
R
That they are... There is a thread about it in the sponsor forum on LS1Tech.
Old May 25, 2008 | 04:39 PM
  #317
I was sworn to secrecy on that one but now that it is public, yes they are. I found out the day I flew there to drive it with Kurt.
Old May 25, 2008 | 04:41 PM
  #318
oh, not sure i've mentioned this yet. I put the new intake on and holy crap it quieted things down. didn't help my IAT's though at all. still seeing 130+ at cruise speeds. Most of the annoying *** whistle is gone though
Old Jun 4, 2008 | 01:08 PM
  #319
BigKID's Avatar
Originally Posted by DanaliHD
...They also said I need to replace my bypass valve. They sell a different one for vehicles with large cams. Something about the spring on the inside being different/removed. It's all over my head but something about the blower building/holding internal boost even and cruise speeds and the new actuator will relieve that boost and in turn reduce heat. Hey, for $100 why not try it.
Did they mention at what vacuume level the upgraded bypass valve is needed?
I checked my truck last night (first time it has run in 6 months) and I have ~16" at idle and cruise. After idling for a fair amount of time to fill the tranny with fluid, it sat for about an hour while I was creating the tune. When I took it for a drive I was seeing low-mid 140 IATs that never came down while I was driving. This is with humid low 80 degree ambient temp. I am hoping the TrickTank will help some but I may need to look into this different bypass as well.
Old Jun 4, 2008 | 01:37 PM
  #320
well, they claim if you don't have 20" vacuum at idle you need the other valve. I got it, tried it, it didn't do jack but make my truck run bad. I sent it back. It would get stuck at 0lbs boost then jump hard to 5lbs. kinda scary.
