My '07 Trailblazer SS 2WD "MagnaCharged"
Old May 24, 2007 | 01:46 PM
  #41
yurs78's Avatar
Originally Posted by 2005SSR6Speed
The dyno numbers below were for a stock installation on an '07 TrailBlazer SS. I have already started changing everything.
Regular 112, stock pulley 2.9, LS2/7 throttle body, 5.5 to 7 psi of boost, 18-21 degrees of timing, 4L70E, 14 Bolt 9.5" rear axle w/Eaton Locker, lowered 2" front and 3" rear and everything else is stock.
I have the transmission out for rebuild now, Kooks 1 7/8" X 3" Headers and 3" Catted Y-Pipe, Short Block is getting Forged Mahle Pistons, Eagle Forged Rods and all ARP Fasteners inside. I want 500 RWHP from this setup before I go the next level.
So you're going to pully down form more boost with this next setup? Sounds killer!!! Will you be using any Detonation control? What did the above set up (before the tranny, headers, bottom end...) put to the wheels? Thanks for all of the help!!!
Russ
Old May 24, 2007 | 02:26 PM
  #42
leftcoast32's Avatar
FormerVendor
Russ
I will pulley down to get 7-8psi of boost after the exhaust and other mods. No need to use alky or anything else at these boost levels.
The stock installation put out 443 RWHP and 423RWT
Old May 24, 2007 | 08:24 PM
  #43
yurs78's Avatar
Sorry for the stupid question, for some reason I thought you were talking about a different TB. I'm very interested to see what you come up with from those mods!! Thanks for all the info.
Russ
Old May 24, 2007 | 09:21 PM
  #44
FormerVendor
Russ
No problem Bro. I am shooting for 500RWHP from the above mods. Then will be a little track time and time to tear it all back down for heads and cam. The eventual goal is a 91 tune with 650RWHP for the street.
Old May 25, 2007 | 09:57 PM
  #45
yurs78's Avatar
HELL YEAH!!!!
Old May 31, 2007 | 01:43 AM
  #46
FormerVendor
The Kooks 1 7/8" Primary w/3" Collector Headers and High Flow Cat Y-Pipe were delivered by the Big Brown Truck. Plans are to have the Cats cut off the Y-Pipe and run Duals all the way back.
Old Jun 1, 2007 | 10:25 AM
  #47
jconner111's Avatar
OMG....just be sure to get a BEAST SUNSHELL, and KEVLAR 2nd band set...that thing is super clean..good job springing the x-tra $700 for the polished case...SWEET!
Old Jun 1, 2007 | 06:02 PM
  #48
Holty's Avatar
Notorious BIG
I used the company below and ordered all the individual pieces. The 4" rubber tubing will slide right on the 90mm throttle body. I used 4" thin wall aluminum tubing from the same company and sleeved the inside of all the junctions. Once it is all mocked up and you have all the angles down then you seal it all together with black silicone RTV. The Maf needs reducing hose inserts (1) 4" to 3.5" and (1) 4" to 3.75". It is real easy to put together and set it up. I cut and sanded all the ends to the transitions it is almost seamless.
http://store.airflo.com/rubber-hoses---clamps.html
http://store.airflo.com/intake-tubing.html
Joe, are you using the stock maf or a 100mm maf?
Old Jun 1, 2007 | 06:41 PM
  #49
Scream's Avatar
MOOBIES Moderator
Looks awesome...I love bling!
Old Jun 1, 2007 | 07:01 PM
  #50
Blown02Sierra's Avatar
wow that looks **** man. That's exactly what i want, i just wish i was ballin hard enough to rock that </gangsturr lingo>
