My '07 Trailblazer SS 2WD "MagnaCharged"
#25
FormerVendor
I used the company below and ordered all the individual pieces. The 4" rubber tubing will slide right on the 90mm throttle body. I used 4" thin wall aluminum tubing from the same company and sleeved the inside of all the junctions. Once it is all mocked up and you have all the angles down then you seal it all together with black silicone RTV. The Maf needs reducing hose inserts (1) 4" to 3.5" and (1) 4" to 3.75". It is real easy to put together and set it up. I cut and sanded all the ends to the transitions it is almost seamless.
http://store.airflo.com/rubber-hoses---clamps.html
http://store.airflo.com/intake-tubing.html
#26
Originally Posted by Brian@JPA
Most of the kit will fit, if you are interested we might be able to set something up for you.
Please PM me with the details. (dont want to thread hijack)
#27
FormerVendor
Originally Posted by CHRISPY
What parts will not fit? Tuning/warranty available? That is what I am most interested in. Bolting it on and having the 3yr 36K warranty you guys offer.
You would need to make a custom intake tube and swap the water pump (depends on the year) to fit the SSR or TBSS kit on yours.
