MSD-8733 two-step
Old 01-22-2011, 12:09 PM
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
Originally Posted by tarinitup
What does it cost?
between $180-250 depending were you buy it
Old 01-22-2011, 12:10 PM
my question is...
can i make it work off my brake pedal when i am on the street and off the transbrake at the track...WITH OUT changing the wires up every time...
i know i will have to adjust the 2-step point between the two
Old 01-22-2011, 02:15 PM
SPAM HUNTER
2005 Silverado's Avatar
Did you put a switch between the ground or the power?
I would use the brake pedal as an arm switch unless you put a second switch in to inturpt the circuit...i dont know if these are made to go on, off, on, off and so on with daily driving just my 2 cents, but i think you could make it work that way.
I found one new for 170...i think i might just have to get it
Old 01-22-2011, 04:57 PM
JoeyGC5's Avatar
Originally Posted by denali_on_26's
my question is...
Yes, it could be as simple as a 1*relay setup, and as complicated as a 3*relay setup depending on how you have everything else wired wired.
Old 08-05-2013, 01:24 PM
idahoblkss's Avatar
i realize this is a older thread but i have a couple questions on this. 1- do you need a line lock or hydro boost for this to work right? 2- are you still using it foose if so how do you like it?
Old 08-05-2013, 04:38 PM
Slowest turbo build ever!
black00chev's Avatar
I can answer ?#1, No you do not need line-lock or trans brake to use a two step. However, if your RPM limit is high enough to push through your brakes then I guess you need something for that.
Old 08-05-2013, 05:10 PM
Chevy_King1500's Avatar
i would say hydro boost is a must, the standard vacuum brakes suck.... mine wont hold my truck back for ****. it just keeps creeping forward
Old 08-05-2013, 06:20 PM
Choda's Avatar
Interesting. So I have a 3k stall and can hold it w my stock brakes at wot to hold it at 3k and 8 psi. If I bought this and set it to 2800rpm. I could use a toggle switch to turn it on and the brake pedal to activate it? What happens at the end of the track when it's slowing down from 6k rpm and I still have the switch on? Will it turn on the 2 step?
How do I get my truck to bark and spit like the big guys? This video didn't seem as nasty as I was hoping
Charlie@LsXperts
09-24-2015 09:58 PM
slowec
09-25-2012 02:10 AM
foose04
05-18-2012 05:31 PM
foose04
04-13-2011 06:32 PM
Bret Kepner
10-29-2009 03:06 PM
Quick Reply: MSD-8733 two-step
