MSD 2320 IAT sensor install = problem!
if you look at the maf you can see the temp sensor in the corner there. you can see in the plug itself that two wires are kinda seperate from the rest. those are the two to use. if the wires you used weren't right beside each other on the end then you have it wrong. other than that check connections. it doesn't matter which way you connect to the sensor.
the plug i bought came with a ton of wire. i also just unloomed the stock stuff to get more. then reloomed it all. i also tape up the maf plug so people don't say "hey this is disconnected". lol
Here is a wiring diagram. Hope it helps. Black and Tan are the correct wires to use to wire the new IAT Sensor.
Attachment 49867
Attachment 49867
zblee
63
Jun 10, 2023 01:25 PM
D1SCSS
Jan 25, 2016 10:14 PM
zblee
Aug 3, 2015 03:45 AM
