MSD 2320 IAT sensor install = problem!
Old Nov 9, 2009 | 10:43 PM
sharpshooter's Avatar
Default MSD 2320 IAT sensor install = problem!
I just installed the new sensor in my intake tube for my meth set-up.I used the black[not the black with white stripe] and tan wires from the MAF and hooked them to the new sensor.I don't think it matters to the sensor which way they are hooked up.
My problem is I now have no IAT reading, it is reading -38* F on my EFI live dashboard scan and I have a check engine light on now.Can these sensors be bad from the store or did I do something wrong?
thanks for any help!
Old Nov 9, 2009 | 10:52 PM
SincalT/A's Avatar
You sure that's not a coolant sensor?
Old Nov 9, 2009 | 10:59 PM
http://www.summitracing.com/parts/MSD-2320/
This is the sensor I bought.
Old Nov 9, 2009 | 11:00 PM
charcold-bowtie's Avatar
sounds like its mined. I had the same problem. Its kinda PITA. Probably a bad connection at the sensor, i would check it there. mine did the same thing but maxed the reading at like 200 something degrees.
I know its the tan wire. But what code is it throwing? maybe you grabbed th wrong black wire
Old Nov 9, 2009 | 11:06 PM
GMCtrk's Avatar
One of the black wires is a ground. You need the one with +5 volts. Try the other black wire. I just got my 2320 IAT sensor in today!
Old Nov 9, 2009 | 11:22 PM
there is a black and a black with a white stripe, everything I've read said the black wire
I'll have to try tomorrow, thanks for the help.
Old Nov 9, 2009 | 11:33 PM
GMCtrk's Avatar
Everything I read regarding tapping the AC wire for electric fans said there was 2 green wires in the loom by the junction box. Well, turns out my truck has 3 green wires in the loom, all of varying shades and one with a white stripe. Took me 3 tries to get the right wire.
Moral of the story is take everything you read with a grain of salt. Im confident your IAT will work with the other wire.
Old Nov 10, 2009 | 12:09 AM
BlackGMC's Avatar
Resident Retard
I think i used black and brown wires.
Old Nov 10, 2009 | 12:31 AM
speaker wire works good for extending these types of things too fyi
Old Nov 10, 2009 | 07:14 AM
that's funny, speaker wire is what I used
