MSD 2320 IAT sensor install = problem!
Old Nov 10, 2009 | 09:04 AM
TURBHOE's Avatar
if you look at the maf you can see the temp sensor in the corner there. you can see in the plug itself that two wires are kinda seperate from the rest. those are the two to use. if the wires you used weren't right beside each other on the end then you have it wrong. other than that check connections. it doesn't matter which way you connect to the sensor.
the plug i bought came with a ton of wire. i also just unloomed the stock stuff to get more. then reloomed it all. i also tape up the maf plug so people don't say "hey this is disconnected". lol
Old Nov 10, 2009 | 05:05 PM
Mort's Avatar
Here is a wiring diagram. Hope it helps. Black and Tan are the correct wires to use to wire the new IAT Sensor.
Attachment 49867
Old Nov 10, 2009 | 05:58 PM
sharpshooter's Avatar
thanks
Old Nov 10, 2009 | 06:23 PM
charcold-bowtie's Avatar
sounds like its a problem right at the sensor. cause if its not hooked up right it defaults to max or min
Old Nov 10, 2009 | 11:01 PM
All my fault, I had the metal connectors in the plastic plug that connects to the sensor to far down in the plug.No contact! It works now.
Old Nov 11, 2009 | 08:30 AM
Mort's Avatar
Good going.....
Old Nov 11, 2009 | 08:46 PM
phasemaster1's Avatar
Great have you logged to see if the sensor is any quicker or lazy than the stocker?
zblee
63
Jun 10, 2023 01:25 PM
D1SCSS
Jan 25, 2016 10:14 PM
zblee
Aug 3, 2015 03:45 AM
Ammadien
Jul 22, 2015 08:50 PM
