MP112 Shift Points?
Old Dec 12, 2009 | 06:17 PM
04gibbstahoe's Avatar
Default MP112 Shift Points?
Just wondering where the ideal place would be to set the shift points on my 1-2 shift and also my 2-3 shift with my magnacharged 5.3L and other mods in my sig. It makes 7-8 lbs. of boost as well.
Old Dec 13, 2009 | 09:22 AM
Doobie's Avatar
I think it depends on your chosen cam as well as the limits of the 112. My set up is similar to yours and I have my 1-2 shift set at 6k, conservative I know but I chose my cam and supporting mods for towing capacity. Many seem to shift at 6200~6500 rpms but I stayed conservative in the hopes of keeping my drive train intact.
Old Dec 13, 2009 | 09:57 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
4L60e With 3.73 I command the shift ~6200 but it shift slightly before that.
Old Dec 13, 2009 | 10:24 AM
richierich14608's Avatar
Basically here is what I am trying to do. Both shifts are set to shift at 5700 rpms and I am trying to find out if I will gain any performance by raising the shift points higher than 5700 with the stock cam?
Old Dec 13, 2009 | 10:26 AM
Sorry to jack the thread but I also would like to know if power is gained by shifting past 5700 on a stock cam as mentioned above?
Old Dec 13, 2009 | 02:53 PM
SILVERADO11's Avatar
I would also like to know if power is gained by shifting past 5700 on a stock cam?
Old Dec 13, 2009 | 06:24 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I wouldn't shift higher than 5800 with the stock cam.
Old Dec 13, 2009 | 07:03 PM
viciousknid's Avatar
Where's the Beef?
I shifted at 6100 with a stock cam N/A so with a S/C i wouldn't hesitate on doing the same. It would be a good idea to swap cams tho.
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
