MP112/15lbs of boost on 402CID 600/700 to the wheels......video link
found this while surfing:
here are his mods:
2001 TR Chev Corvette Z06: 2.65 Maggie on 402ci LS2 w/ ECS 8" Crank, 8-Rib System, 90mm T/B
Well, tonight was the big night!! I had the rear over-drive kit put on and all I can say is "wow'' the car is sick!!!!! I was spining 3rd gear with my 345 bfg's drag radails. O.K now for the big new, I was hitting 15lbs of boost, 15lbs!!!!!!!!!!!! I can hit the throttle at 1500rpm's and it makes 15lbs and keeps the boost right to red line! Remember this is a 402ci ls2 with one sick maggie on top!!!!
here are his mods:
here are his mods:
How I read it is he was "spinning 3rd gear". On a Dyno? With drag radials? Can the BFG DR's handle the dyno without burning up,...my M&H's sure can't.
Anyway, I agree with dewmanshu.
Something doesn't add up here. What was the blower RPM's?
My opinion, calibrate that boost gauge or do some better MAP calculations.
Something doesn't add up here. What was the blower RPM's?My opinion, calibrate that boost gauge or do some better MAP calculations.
The guy is on corvetteforum, there is always alot of controversy surrounding it seems... but I watched an old video a while back and that thing sure rockets out of the hole for sure, runs 10's with old setup. I think its a 6 speed.
I know this from experiance. An improperly indexed cam can mess with the valve events and cause a "back up" in the manifold, showing ALOT more boost than it should. I had this happen once when a local builder built an engine for me. I wondered how in the hell that 10 pound pulley was making 14 psi. In my case though, the truck was down a good bit on power and had a starting issue because the cam reluctor ring was off from where it should have been. Once the cam was instaled "correctly" boost dropped and power came back up to normal.
I am curious how he can be feeding that much air with that blower to an engine of that size?????? I didnt think anyone else has had any success getting that much from the smaller Maggie.
