MP112/15lbs of boost on 402CID 600/700 to the wheels......video link
Old Sep 19, 2007 | 01:03 AM
moregrip's Avatar
what a rush!
Default MP112/15lbs of boost on 402CID 600/700 to the wheels......video link
found this while surfing:
Originally Posted by FunCool
Well, tonight was the big night!! I had the rear over-drive kit put on and all I can say is "wow'' the car is sick!!!!! I was spining 3rd gear with my 345 bfg's drag radails. O.K now for the big new, I was hitting 15lbs of boost, 15lbs!!!!!!!!!!!! I can hit the throttle at 1500rpm's and it makes 15lbs and keeps the boost right to red line! Remember this is a 402ci ls2 with one sick maggie on top!!!!
here are his mods:
2001 TR Chev Corvette Z06: 2.65 Maggie on 402ci LS2 w/ ECS 8" Crank, 8-Rib System, 90mm T/B
Old Sep 19, 2007 | 02:54 AM
thunder550's Avatar
High on diesel fumes
Good god I'd hate to see what his IAT's were on that setup
Is that even possible? I'm thinking
Old Sep 19, 2007 | 05:21 AM
Breeze's Avatar
11 Second Truck Club
My exact thoughts
Old Sep 19, 2007 | 06:53 AM
moregrip's Avatar
what a rush!
the guy has been developing his 112 setup for sometime and has been legit so far
Old Sep 19, 2007 | 07:12 AM
dewmanshu's Avatar
Moderately Differentiated
here are his mods:
and an 1 1/4" single exhaust with 1.05 exhaust valves.
Old Sep 19, 2007 | 07:48 AM
zippy's Avatar
I think I'm finally speechless.
Old Sep 19, 2007 | 08:55 AM
vanillagorilla's Avatar
It probably has a pretty high CR for sure.
Old Sep 19, 2007 | 08:58 AM
krambo's Avatar
How I read it is he was "spinning 3rd gear". On a Dyno? With drag radials? Can the BFG DR's handle the dyno without burning up,...my M&H's sure can't.
Anyway, I agree with dewmanshu. Something doesn't add up here. What was the blower RPM's?
My opinion, calibrate that boost gauge or do some better MAP calculations.
Old Sep 19, 2007 | 09:58 AM
ZO6Ted's Avatar
The guy is on corvetteforum, there is always alot of controversy surrounding it seems... but I watched an old video a while back and that thing sure rockets out of the hole for sure, runs 10's with old setup. I think its a 6 speed.
Old Sep 19, 2007 | 10:32 AM
ranwalk's Avatar
I know this from experiance. An improperly indexed cam can mess with the valve events and cause a "back up" in the manifold, showing ALOT more boost than it should. I had this happen once when a local builder built an engine for me. I wondered how in the hell that 10 pound pulley was making 14 psi. In my case though, the truck was down a good bit on power and had a starting issue because the cam reluctor ring was off from where it should have been. Once the cam was instaled "correctly" boost dropped and power came back up to normal.
I am curious how he can be feeding that much air with that blower to an engine of that size?????? I didnt think anyone else has had any success getting that much from the smaller Maggie.
