More boost?
Old May 30, 2013 | 03:54 PM
mongooseboy000's Avatar
Default More boost?
How are you guys cranking up your boost. I just installed a T72 kb racing with the bigger 10# spring but only boosting 8 lbs. trying to see how some of you are doing 12# plus. boost controller, tune? i only want 10. mods in sig.
Old May 30, 2013 | 04:00 PM
nonnieselman's Avatar
A boost controller should do it for you.
ive used a regular ole air compressor regulator and bench tested it for a couple psi and tried it out. vola. it works on my buddys truck now.. 8psi, flip switch and its 16 after a lil tweaking on his.
Old May 30, 2013 | 05:14 PM
lmao. what boost controller are the best for our trucks
Old May 30, 2013 | 06:02 PM
TrickTurbo's Avatar
Truck Sponsor
Reinstall light spring.
Remove and plug vacuum hose.
You would be on spring only.
So be prepared to lift.
Old May 30, 2013 | 06:05 PM
GMCtrk's Avatar
I'm about to set up the Eboost street and others here are using it.
It's a badass boost controller and it has overboost control so you dont have to worry about overboosting (assuming no mechanical or electrical failures occur). Reasonably priced too right at $290-300
Old May 30, 2013 | 06:57 PM
Beatdown Z's Avatar
Laid Back
You can pick up a boost controller of ebay for about 25 bucks. Just installed one and it works fine.
Old Jun 16, 2013 | 08:02 PM
How much psi u think I will be on this setup? 10-12
Old Jun 16, 2013 | 08:05 PM
TrickTurbo's Avatar
Truck Sponsor
Lots of variable. BP being the biggest one.
That's why mentioned be ready to lift.
Old Jun 17, 2013 | 07:25 PM
Lol thanks. I tried that one big spring n it was 16psi. With no meth or tuned that's asking to blow my 4.8 lol. So I will try again with small spring n if I'm at 10-12 psi ill leave it
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
