Methanol injection
It’s funny the difference in setups. The Meth made little to no IAT change on my Blower setup, but on the turbo spraying post intercooler I am seeing my iats drop about 10 degrees when it sprays. I have it turned down right now and still see IATs that are 10 below ambient at 10psi. I’ll see how it acts as I turn up the boost.
What's everyone's opinion on 50/50 water/meth versus 100% meth when injecting prior to a Magnuson?
Does the ol' "The rotors will get stripped of their coating" story hold truth?
Or how about "The water will hydrolock your engine."
I loved my alky control kit with progressive controller. I did swap out the nozzles for devils own threaded in style. i also used 100% meth M1. its cheap.
Careful which windshield fluid if you go that route. The glycol stuff isn't good for your motor. The methanol/water stuff depends on what area you live in.
A small drum of methanol lasts a while especially if you're mixing on your own and storing it properly.
chrismikolaitis
Feb 11, 2008 03:02 PM
