Meth for trucks
Old Oct 24, 2008 | 12:07 AM
53RUSSELL's Avatar
Default Meth for trucks
How much boost before you needs to start using meth on your truck?
Can go to 10lb with out meth. I have 42lb injector already and new waldo 255
Old Oct 24, 2008 | 06:43 AM
dhpro's Avatar
U can prob run the higher boost, but its all about how far u can push timing before KR limits u. The Meth will offer a wider window before the blower ends up just a heat pump. At some point ur HP stops going up and u just generate heat and KR % starts to advance.
There's lots of better experts than me who can give u a more technical explanation...but thats how I understand it
Old Oct 24, 2008 | 07:04 AM
KySilverado's Avatar
In my setup I ran out of injector @ 10psi. Meth was my crutch for a long while.
Old Oct 24, 2008 | 08:59 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Meth does a few things....increases octane allowing more timing safely, cools (slightly) ....what's that 3rd thing? adds fuel!
Old Oct 24, 2008 | 09:19 AM
dewmanshu's Avatar
Moderately Differentiated
I can answer almost every thread about "when" with 9#'s.
Old Oct 24, 2008 | 10:22 AM
D-GTO's Avatar
I guess I need to shoot for 8.5# then hehehe
Old Oct 24, 2008 | 10:38 AM
thunder550's Avatar
High on diesel fumes
Mine comes on progressively, starting at 4psi and hitting full pressure at 10 psi.
Old Oct 26, 2008 | 10:26 AM
gmc6.0's Avatar
speaking about meth does anyone know where i can get it the fuel.....
Old Oct 26, 2008 | 10:12 PM
trever1t's Avatar
any speed shop, race fuel supplier and motorcycle parts should have it in 5 gal cans.
Old Oct 26, 2008 | 10:29 PM
D-GTO's Avatar
You can always use good old fashioned Winshield Washer fluid. Pay attention to the contents. They don't all have the same ratio of chemicals.
Straight meth is better though if you can find it.
