Meth for trucks
Old Oct 27, 2008 | 10:44 AM
S/C Z71's Avatar
Banned
Meth/H2O injection will benefit you even at 1psi. Blue washer fluid is the ONLY washer fluid you can use. The others contain detergent. Buy some methyl hydrate and mix your own to 50/50 or 60/40 meth/water.
Old Oct 27, 2008 | 11:27 AM
kbracing96's Avatar
If your run WWF like I do, run the -20* blue stuff. An alky kit seller over on Tech said they tested most all the brands of the -20* stuff and they were all right around 30% meth, 2% detergent and the rest is water. Stay away from the orange stuff and the -40* stuff, as most of it also contains glycol (antifreeze) and I wouldn't want to be spraying that into the motor. Also the +32* stuff has little to no meth in it.
Old Oct 27, 2008 | 01:31 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by kbracing96
If your run WWF like I do, run the -20* blue stuff. An alky kit seller over on Tech said they tested most all the brands of the -20* stuff and they where all right around 30% meth, 2% detergent and the rest is water. Stay away from the orange stuff and the -40* stuff, as most of it also contains glycol (antifreeze) and I wouldn't want to be spraying that into the motor. Also the +32* stuff has little to no meth in it.
Glycol, I need to start reading these labels more. LOL
Old Oct 27, 2008 | 01:52 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by 53RUSSELL
How much boost before you needs to start using meth on your truck?
Can go to 10lb with out meth. I have 42lb injector already and new waldo 255
That really depends on many factors. Octance of fuel using, amount of spark, and size of turbo are just a few. Temp. outside, intercooler etc etc.
If you are noticing knock @10lbs with premium fuel, and your happy where your timing is, meth injections will be needed. Air temps are getting way out of controll same thing. If you start to run lean, and can not get the fuel you need and do not want new injectors meth can help.
Each truck out there is different and there is no one rule fits all. Water/meth is a great equalizer and helper with all out performance and safety.
Get a good kit if need be, and start small. Progressive type systems will use less overall water/meth then direct on off type systems.
Old Nov 2, 2008 | 02:54 PM
orangefun's Avatar
11 Second Club
what setup/kit do you recomend for my setup. 5.3 stock with 10#'s of whipple (headers no cats, plenty of fuel/injectors) truck is still in set up stage, tune not done yet, will be custom tune, correct me if i am wrong, meth/water small shot of n20 etc does help add some power but is primarly used to add life to the engine right?? well for boosted applications
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
fcompean
Jul 15, 2015 09:55 PM
Deceptarado
Jul 8, 2015 05:24 PM
