Meth Nozzle Flow Test
Old Feb 12, 2014 | 08:26 PM
  #31
Atomic's Avatar
I have a gauge for that
Alright so I got a chance to revisit this. It looks like my pump voltage was low in the first series, around 6.8v at full blast which is why my numbers were lower. After talking to Julio I tried a couple things and got everything lined up. I upgraded the power wire by adding in an additional 12ga wire straight to the 4ga from the battery. I also adjust the controller "initial" **** to about 1:30 clock position from the 11:30 clock position it was before. I also recorded all the voltages this time.
It looks like from doing this I gained roughly 3.5v at full blast which greatly improved the flow numbers.
Controller set to "1"
Controller set to "4"
Controller set to "8". All the way up.
And here is the last one converted to lb/hr
So if we compare this one to my result last time...
Obviously it is working much better now
It is clear the pump is struggling with 3 nozzles at low controller settings. This would indicate I need more tweaking with the turn on and initial settings to really optimize this. It is clear though the pump is at full voltage by 20psi the way I have it set (voltage readings confirm this).
To put some numbers to it, using 2 nozzles after my latest adjustments at 25psi of boost the system is moving 211 lb/hr. Before at these settings it was 131 lb/hr. Thats a 61% improvement. Comparing to earlier with 3 nozzles at the same settings was 139 lb/hr so a 52% improvement over that.
What im getting at is I did not have the system set up well before, but now there is clearly no need for a 3rd nozzle at this point.
For all of you guys with meth systems, you may want to put a volt meter on your pump to make sure its doing what you think it is
I also attached my spreadsheet if anyone wants to see numbers. The second tab is from the first test I ran with the low voltage.
File Type: zip
Old Feb 12, 2014 | 10:51 PM
  #32
kelsey_canard's Avatar
so the moral of this story: Add a hotwire kit on your meth kit Good study as always!
Old Feb 12, 2014 | 11:16 PM
  #33
BlackGMC's Avatar
Resident Retard
Does hpt have a 12v input on one of the external logging plugs like the 5v ones?
Old Feb 12, 2014 | 11:19 PM
  #34
Atomic's Avatar
Dunno, I use the standard version anyway. Wideband is piped in through the EGR
Old Feb 17, 2014 | 11:17 PM
  #35
Atomic's Avatar
Glad to see everyone saw the update
Old May 21, 2014 | 09:36 AM
  #36
slowec's Avatar
What A/F ratio are you tuning for on 30 GPH meth? I am using 2 M15 nozzles myself.
Old May 21, 2014 | 12:04 PM
  #37
Atomic's Avatar
I aim for around 0.75-0.78 lambda.
Old May 21, 2014 | 12:15 PM
  #38
slowec's Avatar
Sounds good. I am in the low seventies working and tuning my way leaner.
Old Jun 17, 2014 | 08:47 PM
  #39
BlackGMC's Avatar
Resident Retard
So which nozzles are you using with these tests? Alkycontrol or devils own? I noticed you said you liked the devils own better.
Old Jun 17, 2014 | 08:53 PM
  #40
Atomic's Avatar
devils own...nozzle brand shouldnt really matter, just the flow rate and rating point
