Meth Nozzle Flow Test
Old Jan 23, 2014 | 07:31 PM
  #21
03sierraslt's Avatar
Originally Posted by Atomic
Appears that way....the real damage here is I am always going to be paranoid about it now
Looks like I need to make room for another gauge...or at least a 100psi trigger light...
Did you notice any change in the time it took for your LED to turn green? On a plus note, for only getting 6.8V the output is decent.
Old Jan 23, 2014 | 07:38 PM
  #22
Atomic's Avatar
I have a gauge for that
Nope, too many other things to look at. It still made 50psi so the light isnt much help.
Old Jan 24, 2014 | 07:07 AM
  #23
slowec's Avatar
Build a direct port kit using a pump for each bank. (insert evil grin)
Old Jan 24, 2014 | 07:17 AM
  #24
silver-mod-o's Avatar
Hunt&Fisherator
If I ever put meth on anything that's probably the route I'd go for distributions sake. Hard line it all and it would be a very clean install. You'd have a hard time convincing everyone it wasn't a direct port nitrous setup though
Old Jan 24, 2014 | 08:08 AM
  #25
Atomic's Avatar
I actually thought about that having nitrous outlet or someone make some spray bars in the intake, but shyed away because of the cost.
Old Jan 24, 2014 | 08:31 AM
  #26
Chevy_King1500's Avatar
so when are you switching to e85.
Old Jan 24, 2014 | 09:01 AM
  #27
Atomic's Avatar
Whenever you want to donate $1500 to upgrade parts
Julio has been very helpful with this, he gave me a few things to try over the weekend to narrow down the problem.
Old Jan 24, 2014 | 10:21 AM
  #28
Vortec350ss's Avatar
Still cool info despite the low voltage... as of now you're spraying enough meth to hydro-lock my engine though
Old Jan 25, 2014 | 06:01 AM
  #29
black4.8's Avatar
Interesting atomic, I use two 14gph devils own nozzles and pump turned all the way up. Didn't know how much pump could handle.
Old Jan 25, 2014 | 08:02 AM
  #30
TrickTurbo's Avatar
Truck Sponsor
Direct port.
Good thing tunability.
Could tweek each cylinder if you are that deep into the weeds.
Pulling every once of power out if it.
Which most aren't.
Looks cool.
Bad
Spendy. But if your at that level not a big deal.
Will not be able to watch temp drops since air temp sensor is way up stream.
Complex to set up.
Having 8 discharge ports means smaller nozzles.
Easy to get clog or corrode.
