Meth Nozzle Flow Test
Old Jan 23, 2014 | 11:16 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by Atomic
Not sure about the screw but the spreadsheet has the pressures in it. Most i saw was 100psi, it behaved like an internal limit.
Interesting. I thought most meth pumps were rated at 250-300 psi. I could swear i read that in some specs on them.
Old Jan 23, 2014 | 11:19 AM
TrickTurbo's Avatar
Truck Sponsor
Im betting Hi psi but not hi volume.
Old Jan 23, 2014 | 11:31 AM
Atomic's Avatar
I have a gauge for that
I know the AIS pump says its pre set to 200psi and is adjustable from 100-300psi, but that says nothing about flow. The alky control pumps are pressure tested to 250psi. It seems none of these guys want to give you a pump curve, which is what I basically made anyway.
Old Jan 23, 2014 | 11:33 AM
thewrx's Avatar
Good stuff.
Old Jan 23, 2014 | 11:55 AM
TrickTurbo's Avatar
Truck Sponsor
Black magic secret stuff. .
Still good info.
Old Jan 23, 2014 | 06:40 PM
Atomic's Avatar
So I think my pump may be weak/going out... Waiting on a reply from Julio.
Old Jan 23, 2014 | 06:46 PM
03sierraslt's Avatar
I just got mine back from him, sent it in for a rebuild. I am running a single 15gph however I have been considering going with two smaller nozzles, just not sure if I want to go with two 10's or not.
Old Jan 23, 2014 | 06:59 PM
Atomic's Avatar
Pump was only getting 6.8v, put 12v directly to it and pressure jumped 50psi with the 2 14s in there. Leaning towards a controller issue...
Old Jan 23, 2014 | 07:08 PM
So your above tests were with low voltage?
Old Jan 23, 2014 | 07:26 PM
Atomic's Avatar
Appears that way....the real damage here is I am always going to be paranoid about it now
Looks like I need to make room for another gauge...or at least a 100psi trigger light...
