meth...love it
Old Oct 2, 2010 | 12:26 AM
EVILGMC's Avatar
Default meth...love it
Finally got the meth tune in and holy assfuck batman.. its a night and day difference. Can't wait to get it on the dyno and to the track.
Here is the setup:
Alky control progressive kit
15 gallon nozzle
Washer reservoir
VP M1 with top end lube. No water.
2.8 rip pulley for 15psi.
22 degrees of timing.
Old Oct 2, 2010 | 12:39 AM
Pooki's Avatar
This is good news for sure.. I am going to be starting my Alky Meth install next week if things go as planned. Im going with a M10 nozzle to start and see how it does. Im at 18 degrees timing rite now and hope to get more out of it with the tune. How much timing were you running before the Meth Evilgmc?
Old Oct 2, 2010 | 12:44 AM
Blownme's Avatar
Congrats!
I hope to one day run meth and know how it feels. Although I've been thinking of getting rid of the maggie and going turbo.
Old Oct 2, 2010 | 12:58 AM
Dezert1500's Avatar
Night and day difference Pat, your truck mooooves. Just when you left me by a football field, you now leave me by two. **** it, I'm pulling my engine this weekend, I can't take this slowness anymore.
Old Oct 2, 2010 | 10:28 AM
1Bear's Avatar
Here is the setup:
15 gallon nozzle
Washer reservoir
You may want to check, but in the past they didn't want you to use top end lube with their pumps. Alky Control may have changed pumps since I purchased mine, however on the older pumps they didn't want oil introduced into the pump. A friend of mine had the exact same set-up as I do and kept experiencing a leaking pump and it was determined that because he was using the methanol from his race car that had top lube in it, that it was the problem. Also, depending on where you mounted your pump (down on frame rail), water can become an issue for the pump motor and also since I've purchased mine, Alky Control has come out with a rubber sleeve to prevent water from entering the pump motor. Yours may already have the newer sleeve or at least you can pick one up from them.
Other than that, I’m glad you’re experiencing good results from your kit.
Old Oct 2, 2010 | 10:47 AM
scooter k's Avatar
I just talked with Julio at Alkycontrol. He said "no" top end lube, it ruins the pump. He has the covers in stock as I just got one too.
Old Oct 2, 2010 | 03:46 PM
EVILGMC's Avatar
ill need to talk to him. my tuner hs been using the lube with the sureflow alky control pump for a while with no issues. i am diluting it 1.5oz to 5 gallons. time to do some research.
my kit has the cover on the pump.
Old Oct 2, 2010 | 03:53 PM
double047's Avatar
14 Second Truck Club
Great news I want to run a kit when I do my TVS2300.
Old Oct 2, 2010 | 06:02 PM
Rick_Vor's Avatar
I asked Julio about running E85 and he told me the same thing. Also heard the same from a Snow tech. Any oil or gas will ruin the pump.
Rick
Old Oct 2, 2010 | 07:11 PM
scooter k's Avatar
I ran the first 5 gallons with M2 top lube in there and he told me none needed.
