meth...love it
Old Oct 3, 2010 | 03:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
yeah, I was going to ask you about that....no oil products per Julio. According to him, even traces reak havoc with the seals.
Oh and congrats! that's a bus load of timing!
Old Oct 3, 2010 | 06:36 PM
EVILGMC's Avatar
I wonder if the pump can be fitted with viton seals that would be oil safe
Old Oct 3, 2010 | 06:57 PM
350SS's Avatar
I'm ignorant to meth fueling, but why is top end lube needed if it is only supplementing gas fueling? Does the gas not provide valve/ring lubrication?
Old Oct 3, 2010 | 07:30 PM
1Bear's Avatar
The pumps have already been re-built by Julio to be the only pump that I’m aware of that is compatible with 100% methanol, so I don’t know if the seals were changed again if they would still be 100% compatible.
Old Oct 3, 2010 | 07:37 PM
fastnblu's Avatar
Originally Posted by Rick_Vor
I asked Julio about running E85 and he told me the same thing. Also heard the same from a Snow tech. Any oil or gas will ruin the pump.
I know nothing on meth. other than it's corrosive. That said, what's the reason you guys (that are) run top lube in the 1st place? Or at least the thinkin behind doin so?
Old Oct 3, 2010 | 08:07 PM
1Bear's Avatar
Originally Posted by fastnblu
I know nothing on meth. That said, what's the reason you guys (that are) run top lube in the 1st place? Or at least the thinkin behind doin so?
Methanol is corrosive to metals, gaskets and seals. It’s hard on the valve guides and can cause cylinder bore wash, so people use a "top lube" in order to combat the corrosion and lubricate the various components.
Old Oct 5, 2010 | 11:47 AM
jdgoodcat's Avatar
My pump and resivoir is in place.. Wiring up boost switch today.. More info on top lube??
