meth injection guys CHIME IN!!
Old Nov 2, 2006 | 07:45 PM
  #31
kbracing96's Avatar
Here is where I put mine and taped into the washer tank.
Old Nov 2, 2006 | 08:54 PM
  #32
whoopassracer's Avatar
thats what im going to do the same thing right at the bottom
but where did u mount ur pump
Old Nov 2, 2006 | 09:13 PM
  #33
kbracing96's Avatar
Its on the bottom of the frame, right in front of the cross member. Its lower then the tank. Pumps are a lot happier when they don't have to suck up hill for a prime.
Old Nov 3, 2006 | 03:16 AM
  #34
Denali Down Under's Avatar
Well, here's my setup. I made a meth tank out of some 6" UPVC pipe - holds about 3.5 gallons and only cost a few $$ to make. Mounted it under the cab, to the front of the fuel tank - there's enough room there to mount 2 of these. Pump sits on the chassis right beside the tank.
The meth nozzle is just after the MAF, at the back of the 90* bend. You don't even notice the thin black hose going to it - it looks exactly like the cable used to pop the hood.
And here's the switch for it, as well as some lights to show when it's on/low.
Old Nov 3, 2006 | 04:42 AM
  #35
Wilde Racing's Avatar
How do I change this text
That is one Clean looking switch panel...
Old Nov 3, 2006 | 08:15 PM
  #36
well i started installing the kit but wont finish till 2morrow
Old Nov 4, 2006 | 10:40 PM
  #37
well i got everything installed except the wiring. but who has a dual nozzle setup with pics please post.
Old Nov 5, 2006 | 11:14 AM
  #38
well i tried putting the pump on the driver side right above the swey bar and well since i have a 4/6 drop the pump would hit the swey bar so had to relocate. so i put the pump on the passenger side in between the antifreeze coolant tank and the firewall. Now is that going to work out or do i need to relocate so that the pump and tank and be close together
Old Nov 5, 2006 | 11:56 AM
  #39
Mort's Avatar
Cool
You should try to locate the pump so that the pump's inlet is lower than the outlet on your supply tank. That way it will be gravity fed and will never lose its prime. If you mount it higher than the outlet and it loses its prime you may run dry and not get the prime back. It happened on my STS system and I got alot of KR. It took me awhile to figure it out. I was lucky it did not do a lot of damage to the engine but I was running 50/50 meth/water and not really using the meth to supplement fuel.
Also you should instal your nozzle in the intake track so that it is higher than your supply tank so that meth will not be siphoned into your intake when the engine is not running. If this happens it might cause a hydrolock when the engine is started and fubar a piston or rod.
Old Nov 5, 2006 | 11:59 AM
  #40
ok sounds good well i'll try and relocate the pump so it'll be lower than the tank.
