Meth Guys.. ?
Old Jul 19, 2010 | 04:51 PM
DoubleTrouble's Avatar
Default Meth Guys.. ?
I'm looking at getting an alky control meth kit for my truck and I'm not sure how much boost or what kind of meth mixture I should run. I have a LQ4 6.0 liter with a turbonetics t62 and I'm only running 6lbs of boost. I know the turbo is probably a little undersized but it's what came with the kit. I have 42lb marine injectors; according to their duty cylce they should handle about 8lbs of boost and I'm hoping with the meth kit I can run about 10-11 lbs. Does this sound about right? How many lbs would be safe for the stock block as long as I have meth?
Also, what mixture of meth should I run? The guy at alky control said that he would run straight meth because at lower boost levels its better with atomization especially in winter time. However, I know a lot of people run a 50/50 mix. He also said with straight meth you don't have to "play chemist" when mixing the meth which would cause the tune to be off if the meth mixture is off (although I'm pretty sure I can measure to be pretty exact). However it seems like I could run more timing if I had 100% meth which would result in more power.
This is my daily driven truck and I want to keep it safe, but equally important I want to add more POWER. Any feedback/suggestions/comments are appreciated.
Old Jul 20, 2010 | 01:59 PM
bump.. somebody has to know about meth
Old Jul 20, 2010 | 02:08 PM
lownslo's Avatar
i wouldn't rely on meth to run more boost. It only takes once to run low on meth and pop the motor. I would use it as a cooling agent, as well as octane booster. You only want to run enough meth to cool the charge and allow the timming to be bumped.
Others might have a different opinion about this but if it were me, I would look into bigger injectors and just run straight meth and bump the timming. IAT's will drop and still make the same power year round!
Old Jul 20, 2010 | 02:35 PM
Atomic's Avatar
I have a gauge for that
You need bigger injectors. Power is directly related to how much fuel you get in there, and if you are about to up the boost you need more fuel.
Old Jul 20, 2010 | 02:40 PM
TX Tahoe Z71's Avatar
Go E85! Runs cooler, higher octane, much cheaper than 93 and very knock resistant!
Old Jul 20, 2010 | 03:00 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Listen to Julio, he knows what he says. Straight meth. Get the bigger injectors, use the meth as an octane boost
Old Jul 21, 2010 | 04:46 PM
dhpro's Avatar
Ditto
Old Jul 21, 2010 | 10:19 PM
Rick_Vor's Avatar
Ditto x 2.
42's are too small for 10lbs on a 6.0l. I was at about 105% when I ran 42's at 10lbs on a P-1SC. Bumped to 60's when I added the turbo's and used 100% Meth for octane. Over 2 years now and never a problem. With 60's, your tuner can supply enough fuel to run the engine (with some KR) if the Meth runs dry so you won't smoke the motor.
Rick
Old Jul 22, 2010 | 06:23 AM
slowec's Avatar
Its never done is it???
Old Jul 23, 2010 | 05:15 PM
Thanks guys for the help. I'll probably be going with 8lbs (as long as my injectors can handle it) and 100% meth.
Nope, it's just began!!
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
gavin2005
Sep 13, 2015 09:04 PM
