meth fire balls
Old Apr 29, 2009 | 08:20 AM
  #21
TURBHOE's Avatar
it runs high tens low 11 afr. i think its not deactivateing fast enough when i let out. its the sts kit. i'm still tuning. i found it easier to set up the BE and PE to work with the meth instead of trying to tune the ve table around the meth.
Old Apr 29, 2009 | 08:25 AM
  #22
2005 Silverado's Avatar
SPAM HUNTER
Just so you know, some aggressive polish will take care of that "blued" section, found that out on Chris's truck when i detailed it for him last year.
Dustin
Old Apr 29, 2009 | 09:46 AM
  #23
ducky's Avatar
My buddies said I have thrown out some pretty good footlong flames decelerating
Old Apr 29, 2009 | 06:39 PM
  #24
TURBHOE's Avatar
when i first started retuning this thing i was way rich. which is why its black like that. i finally got it almost right. it hits low to mid 12 afr when i roll into boost with tcc locked. like going up hills and what not. then when i go wot its 10.8-11.5 . there is a few odd ball spots where i hit 9's but i can't get it figured out just yet.
the fire ball comes after a wot run. ........i think. i'll try to make a video so we can see.
Old Apr 30, 2009 | 01:15 PM
  #25
S/C Z71's Avatar
Banned
You need a tune. She's running too rich.
Old May 11, 2009 | 02:35 PM
  #26
2ksleeper's Avatar
My bumper on my truck looks the same. I use Eagle One All wheel & tire cleaner, spray it on the bumper and tail pipe & hose it off to get the residue off. Although to get my magnaflow s/s tip clean it take some more work with mothers mag polish to get it clean.
Old May 11, 2009 | 03:07 PM
  #27
TURBHOE's Avatar
i still need to make the vid just haven't had time. but its spot on in the tune when wot. i do need to clean it and see if its still doing it.
Old May 11, 2009 | 03:34 PM
  #28
ssavalanche's Avatar
Wish I had a vid of the Procharger vette that did the fireball on the dyno a couple of years back. On decel from a run, it belched dual 3 foot flames. It was running fatter than the wideband could read, when the afr got right, it was much better. But in any case. I think that with a little DFCO tuning, I think that it should could completely go away.
00loudchevy
Dec 3, 2015 05:54 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
