Injectors, 8.1L cam headers, whipple
So i see that most of you all are running bigger injectors, and they need to be 62lb or bigger. My question is this, are truck lbs different than car. Reason i ask is my friends with camaros and vette said that 62LB injectors are good for like 800 hp. also do i need low or high impedance.
The car injectors are the same as the trucks, however you will need to use a spacer in the fuel rails because the car injectors are taller. Also you will need to get the harness adapters for the car injectors, as the plugs are different teh truck ones. Get in contact with https://www.performancetrucks.net/fo...er.php?u=58322. He has what you want.. Reworked 42lbrs to the 60's. No harness no spacer needed for them, plug and play
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Raylar Engineering
Aug 26, 2015 10:36 PM
