Metco pulleys installed in place of Radix idlers
Old Jun 20, 2006 | 01:24 PM
Holty's Avatar
Notorious BIG
Default Metco pulleys installed in place of Radix idlers
Well, thanks to Frank @ Revolution Race Works getting me my idler pulley spacer in time, i was able to get my 100mm metco pulleys installed over the weekend. Everything was really easy and the install went smooth. Only two things that i need to mention. First, i didn't expect to have to use a longer belt, but i had to go from my 110.5" Gatorback to a 111.5" Gatorback. LUCKILY, i had one already sitting in my garage. the 110.5" belt WOULD NOT go on even with the idler pulley slid all the way up and the tensioner wide open. Did anyone else have this issue? Second, the first few WOT runs i did, i got MAJOR belt slip and belt dust everywhere! it now seems to be holding ok, so maybe the belt just needed broken in? don't know, would like some opinions from you guys on this. thanks.
Old Jun 20, 2006 | 01:44 PM
Whippled 496's Avatar
looks good! Nice and clean too.
Old Jun 20, 2006 | 01:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
Glad it all worked out. Frank is an outstanding guy
Old Jun 20, 2006 | 01:58 PM
JimS's Avatar
Been running mine for about 2 months with no issues.
Old Jun 20, 2006 | 02:04 PM
moregrip's Avatar
what a rush!
I have over 80 passes on my metco pulleys, good to go
Old Jun 20, 2006 | 02:19 PM
krambo's Avatar
Nice! Really cleans up the front alot. Makes it look more "high performance".
Old Jun 20, 2006 | 02:59 PM
dewmanshu's Avatar
Moderately Differentiated
I did mine this weekend as well. Although I was able to get my 111.0" back on. So I am 1/2" shorter, no slip issues here!!
Old Jun 20, 2006 | 05:46 PM
Holty's Avatar
Notorious BIG
is it normal that a new belt is gonna slip real bad like that? or do you think its slipping because i have the longer belt on there?
Old Jun 20, 2006 | 06:00 PM
moregrip's Avatar
what a rush!
I have always liked the gates belt
Old Jun 20, 2006 | 08:07 PM
BLOWN 364's Avatar
Gates and steel radix pulley work the best.
