manifold swap around(not flip)
Old Jun 27, 2014 | 06:14 PM
LOWnEASY's Avatar
Default manifold swap around(not flip)
What do you guys think about swapping the manifolds around,(passenger to driver side etc)
And run a u bend to the turbo up from the passenger side Mani
BTW its a 95 rcsb 4.8 4l80.
This is just something I'm "building" in my head. Haven't look to even see if there would be enuff room but if memory serves me correct, I believe it would work.
I guess my main question is, how would the 180° bend affect the flow? There may even be enuff room to make a longer sweeping bend
Old Jun 27, 2014 | 07:48 PM
mitchellmade's Avatar
MASS seller approved
like syclones are stock?
Old Jun 27, 2014 | 07:58 PM
If you have a welder, anything is possible with a set of truck manifolds. On my next build I wont even try to build a log , I will cut the manifolds and add heavy wall pipe/v-bands. Flipping the manifolds and relocating the coils works pretty good also. Good luck with the build and post pics.
Old Jun 27, 2014 | 08:12 PM
LOWnEASY's Avatar
How do you plan on welding to the cast manifolds1969x11?
The reason I don't want to flip is cause its a shorter run for the driver side to go in front instead down under and arond the oil pan and over the upper a arm and no custom plug wires or coil relocate/flip. So the way I have it pictured in my head, there should be less bends= less welds= less headache.
So 45° to get vertical then 90° to run horizontal to the passenger side, 90° back up, merge with my u bend off the pass Mani in to a t4 flang. Then make a down pipe. I know it won't be that simple, but it sou D's good haha
So all in All should be a $200 or less hot side if I shop around
Old Jun 27, 2014 | 08:17 PM
With a mig welder.Look over in the forced induction section on ls1tech , lots of builds with people slicing on stock manifolds.
Old Jun 27, 2014 | 08:44 PM
LOWnEASY's Avatar
Wonder if I'm going to be able to clear the steering gear box?
Old Jul 7, 2014 | 04:51 PM
idahoblkss's Avatar
this is how we welded my cast manifolds...
heat to 500*
bury in sand to obtain the heat...
weld and make pretties ...
Old Jul 7, 2014 | 04:59 PM
BigBlock90's Avatar
i used stock manifolds on my 90' truck with ls swap aswell. i run the passenger side stock and ran a passenger side on driver side with a vband on front and cut the rear out and welded a vband on and built a crossover and hooked it up. its basicaly the look of a trick or kb kit but swapped sides.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
Jake99
Aug 8, 2015 07:56 AM
Hmguyton
Jul 7, 2015 03:29 PM
