Magnavolt questions
Old Dec 18, 2010 | 06:29 PM
brent1976's Avatar
11 Second Club
Default Magnavolt questions
What size of wire does the wiring harness on a magnavolt have for the actual fuel pump wires? I wired in 10ga wire for the fuel pump, and don't want to wire it into 16ga and melt the insulation off. Does it have an actual wiring harness with a pigtail, or a terminal strip to wire it into the fuel system.
Old Dec 18, 2010 | 09:56 PM
terravast4's Avatar
It has a wiring harness that plugs into the magnavolt and it also has a inline fuse but not sure of the wire size....It is pretty thick though.
Old Dec 19, 2010 | 09:47 AM
dewmanshu's Avatar
Moderately Differentiated
http://www.magnacharger.com/pdf/manu...umpbooster.pdf
I can't tell from the pics, maybe a 12 wire (the grey wire). 12 would be fine.
Old Dec 19, 2010 | 07:58 PM
Gadgetized's Avatar
Don't forget the Magnavolt doesn't run constantly, so it will only be on for a few seconds at a time.
Old Dec 20, 2010 | 07:42 PM
brent1976's Avatar
11 Second Club
The power wire goes in line of the existing wire though, right?
It will be battery-magnavolt-10ga power wire, or am I wrong?
Old Dec 20, 2010 | 11:15 PM
terravast4's Avatar
The magnavolt harness ties into the underhood fuse box
Old Dec 23, 2010 | 03:03 PM
hog's Avatar
hog
Even at WOT, it doesnt run constantly? So the voltage isnt boosted all teh time?
Interesting.
peace
Hog
Old Dec 23, 2010 | 05:37 PM
Gadgetized's Avatar
It is activated by boost. If you are into boost then the magnavolt is working. When you are cruising your fuel pump runs at the normal battery voltage.
Old Dec 23, 2010 | 08:54 PM
brent1976's Avatar
11 Second Club
Interesting.
peace
Hog
The only one that works like that is the msd one, but you can program it to do anything you want with a usb cord, and laptop.
Old Dec 24, 2010 | 08:34 AM
hog's Avatar
hog
OK thanks, I would think that you would want the pump voltage increased while in boost.
peace
Hog
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
