Magnavolt ?
Old May 3, 2007 | 06:43 AM
wkdivr's Avatar
Default Magnavolt ?
Ok....my fuel pressure is reading 56psi at idle- 50psi at wot. It's been about 25,000 miles since my Radix install , with the Walbro in tank pump. I figured with my other mods I would need to get the Magnavolt to back things up. I made some test runs yesterday, and still at 50psi wot. How do I tell if it's even working? I took my rpm signal directly from the pin#10 on the green pcm plug, yellow from Magnavolt with yellow from intercooler to the fuel pump line coming out of the engine fuse box, grey from Magnavolt to grey fuel pump line leading back to the pump. It's an 04 with the returnless system. Any help would be great.
Old May 3, 2007 | 07:14 AM
KySilverado's Avatar
I think you could monitor voltage to the pump. If I understand it correctly it increases the DC voltage when triggered. I am guessing somthing like 14.1 volts to the pump until its triggered and then up to 16-18V?
Old May 3, 2007 | 08:53 AM
BlownChevy's Avatar
blownerator
25 Year Member
Thats a big 10-4!
Old May 3, 2007 | 09:03 AM
wkdivr's Avatar
But shouldn't I see a fuel pressure increase as well? More voltage to the pump means more pressure, or am I missing something?
Old May 3, 2007 | 10:05 AM
Pressure is controlled by the FPR. Pressure=resistance to flow. If there is enough fuel flow/volume the fuel pressure will stay at the FPR setting. If there is not enough fuel flow the pressure will drop.
EDIT: This works for the return system. Dunno about fuel pressure control on the returnless but same principles. Just installing the boost a pump won't increase pressure this is a function of the FPR. It will only keep pressure from dropping off if there is a volume of fuel issue.
Old May 3, 2007 | 10:24 AM
BlownChevy's Avatar
blownerator
25 Year Member
To a certain degree yes.....Check to see if you are getting 17.4 volts at the pump under boost/rpm criteria.
Old May 3, 2007 | 06:46 PM
cyazo6's Avatar
what is the fuel pump that comes with the Radix kit for the 04 truck? A 255lph?
Old May 3, 2007 | 06:48 PM
BlownChevy's Avatar
blownerator
25 Year Member
Yepper
Old May 3, 2007 | 08:17 PM
wkdivr's Avatar
I'll try to check in the next week, or so. Right now, I'm busy helping rebuild Holty's truck. Basicilly from the ground up. I'm sure he'll post pics. Thanks B!
62nalide
Apr 16, 2012 09:55 PM
comhertz
Jun 11, 2010 07:11 PM
Bill Reid
Feb 4, 2008 10:18 AM
2004SSS
Jan 9, 2007 08:20 AM
Holty
Aug 7, 2006 03:13 PM
