Magnacharger Slop
I just picked up a used Maggie 112 and have a concern about it. It's got some slop if you turn it back and forth, not sure if it's normal or not...I'm thinking not. A buddy of mine familiar with these came with me to check it out and he said it should NOT be like that. Says there should be a little more resistance to turning and it should be tight with no slop whatsoever. I still managed to get it for a price way too good to pass up and I'll get it fixed if need be.
Here's a video trying to show the issue:
The "knock" was done on purpose by switching from one direction to another to try and display the issue. It spins relatively freely in both directions, bearings feel good and tight, it just has slop.
First, is it normal and should I be worried about it?
Second, if it's not normal has anybody seen this issue before? What's wrong with it? Is it a simple fix? I'm very mechanically inclined, so can I just pick up a replacement piece and rebuild it? Do I need to send it to Maggie for rework? Should I just buy a new top unit and not worry about it?
Any info would be appreciated, I'm in the dark about it at this point. Figured I'd try and get some info from you guys before I tear it apart.
Yah that sure doesnt sound good. There should be more resistance. Ask the seller were you got it if hes ever had it apart before. Theres alot of parts that work in squence when it spins. He might have forgot or missed somthing when he re assembled it. Theres a few Maggie pros on here. Im sure they know problem.
Mine did not have any slop in it when turning it by hand, and it made suction with the slightest turn (there was tape closing off the end of the j-tube, and you could see the tape getting sucked back and forth). Prob be best to have Magnacharger check it out before you spend an entire day putting the thing on only to find out there's a problem with it. Keep us posted
Thanks
I watched your vid, and that is looking normal to me. I'm comparing it to my own truck, which I installed brand new, and two other trucks(customers of mine) that I work on regularly. All three have the MP112, and all three are like yours.
TX, you might wanna slip your belt off and recheck yours, then post up. Your answer will change.
The Nose Drive has a "torsional isolator" to dampen the load on and off throttle. If you are interested you can pull the nose drive off and inspect the isolator, if it is in fact damaged we have an oil change kit (29.95) that includes a direct drive molyguard that will eliminate this. You will get more noise and potential rotor knock with a molyguard.
The more I listen to it, the more I think there might be an issue.....pull the nose drive off and inspect it.
