Magnacharger/nitrous
Old Oct 23, 2006 | 01:04 PM
  #101
NXRICKY's Avatar
Former Vendor
Originally Posted by moregrip
excellent work!
How do you get the tubes to seal in the holes drilled considering they will be under positive pressure?
Thanks,
I use a thread sealing compound, that is good for .010 gap. The tube to wall gap is only .004 so se we are covered there. I have been going over pics Chris was nice to send to me. The water neck and altenator area is in question? But once I get this into someones hand that has the unit on their truck I am sure it will be fine.
50hp is as low as we can go on HP...
Attached Thumbnails Magnacharger/nitrous-100_1463.jpg
Old Oct 23, 2006 | 01:38 PM
  #102
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by KySilverado
For some reason I see an interference with tubing on the front in my mind. Have to get home and pop the hood on the truck. Maybe I'm wrong. Is there room for the snout support in front of the hook ups tab?
That caught my eye also.
Old Oct 23, 2006 | 01:45 PM
  #103
NXRICKY's Avatar
Former Vendor
Yea, nothing a little tweaking, bending, can not handle. I think if it does hit the water neck. All I have to do is raise that corner a smig-gen. No big deal with the tubes on the outside they can bent to fit around that neck.
Old Oct 23, 2006 | 02:02 PM
  #104
BlownChevy's Avatar
blownerator
25 Year Member
looks sweet, thats for sure!
Old Oct 30, 2006 | 10:05 PM
  #105
1SlowHoe's Avatar
Destroyer of Transmissions
Hows it coming along? .
Old Oct 31, 2006 | 09:15 AM
  #106
NXRICKY's Avatar
Former Vendor
Well I threw it away. Just kidding. the plate is done and even had room to tweek the lines up on the passenger side and should clear that water neck.
The injector height issue is still undesided.
Just about to send one off to a shop for review, and maybe a little dyno time would be nice.
Do you know anyone else that might want one of these.
Sorry for the delays, but I get pulled off one project to work on other ones on a regular basis.
New bottle opener took longer then it should have.
Ricky
Old Oct 31, 2006 | 09:36 AM
  #107
thunder550's Avatar
High on diesel fumes
MEMEMEMEMEMEMEMEEEE!!!!
Old Nov 10, 2006 | 09:07 AM
  #108
NXRICKY's Avatar
Former Vendor
https://www.performancetrucks.net/fo...21#post3485221
I started a new thread.
Ricky
