Maggie pinned crank cam swap?
Old Nov 15, 2014 | 08:33 PM
Jetn3's Avatar
Default Maggie pinned crank cam swap?
On my last cam swap I pinned my crank using the magnacharger crank pin kit. I'm planning on another fi cam swap and was wondering how to reinstall the crank pulley. Do I line up the previously drilled holes or redrill new holes?
Old Nov 17, 2014 | 12:09 AM
08cheyennesc's Avatar
Try to line them up, if you can't then just make new ones
Old Nov 17, 2014 | 10:08 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I usually spend the extra time to line the old ones back up. But if you are unsuccessful, you can re-drill.
Old Nov 17, 2014 | 10:58 AM
Jetn3's Avatar
OK cool, Just what I needed to know. Thanks guys
Old Nov 18, 2014 | 06:34 PM
vettelovralexand's Avatar
How about if you have a pinned crank pulley and swap to a different pulley? Everyone just redrill at that point?
Old Nov 20, 2014 | 09:45 AM
boostedsl2's Avatar
I haven't had the pleasure of installing a pulley after a pin, but i wonder if you could use a drill bit to keep it lined up while you're pressing it on? I think you'd have to press on with the drill guide that came with the kit to keep the drill bit true. A socket might get in the way now that i think of it.
Old Nov 20, 2014 | 11:19 PM
Jetn3's Avatar
Any pics of DIY 2-piece timing covers? - LS1TECH
Here's what I'm gonna do so I don't need to remove crank pulley any more, DIY 2 piece timing cover. Also it will be quicker to do cam swaps. Link to pictures are on post #6
chevyl33
Aug 24, 2015 08:21 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
