Turbo Questions
Old Nov 19, 2014 | 09:07 AM
HawaiianBoyyyy's Avatar
Talking Turbo Questions
Christmas is coming up and I've been saving for a while now think its finally time to turbo my truck. Can someone help me out with a list of exactly what I need?
Old Nov 19, 2014 | 02:22 PM
Kalehuawehe2646's Avatar
Hey a fellow local boy!!! Aloha!!!
Old Nov 19, 2014 | 05:40 PM
69Camaro427's Avatar
They're going to need to know your set up and more importantly desired power goals or track times.
Old Nov 20, 2014 | 09:42 AM
boostedsl2's Avatar
Are you building your own or are you buying a kit?
Old Nov 20, 2014 | 11:50 AM
Atomic's Avatar
I have a gauge for that
How much money do you want to spend?
Old Nov 20, 2014 | 12:51 PM
oakley6575's Avatar
Cheap-Reliable-Fast
You can only choose two. Check out my build thread in my sig. About a quarter of the way through it, I went turbo so I have a pretty good list of parts in there.
Old Nov 20, 2014 | 01:56 PM
cpolaris502's Avatar
Turbo, tubing, fuel pump, oil line, fittings, welder, wastegate, blowoff valve, vacuum line, gauges, transmission, wheels, lug nuts, valve caps. With the exception of valve caps, all of these things will be needed.
Seriously, you can't learn it all in an hour. Sit down and start reading about turbo systems if it's your first. Once you understand it all, it's pretty easy to figure out a parts list. Getting into the exact details is a little more confusing.
Old Nov 21, 2014 | 01:45 PM
Thanks fella's!
Old Nov 21, 2014 | 01:46 PM
I have around 4200$ to spend, and no Im not buying a kit, a local dude is building my manifolds, piping, and etc. I just need to buy the parts
Old Nov 21, 2014 | 01:48 PM
Sup bruda!!
