Maggie ID
Old Jan 6, 2011 | 02:37 PM
vortecyota's Avatar
Default Maggie ID
Can you guys tell if this is a 112 or a 122? It was pulled from a 2002 2500HD with a 6.0L. Thanks! I did a 2004 LQ4/ 80E swap into a 92 GMC last year for a customer and he is toying with the idea of Magnacharging it. I doubt he will ever try to max it out so I wonder if a 112 would be ok for his intentions. It will never see the track, he just wants a little more than stock. Opinions?
Old Jan 6, 2011 | 03:52 PM
Bigredmariner's Avatar
Looks just like my 112.
Old Jan 6, 2011 | 03:55 PM
Preston129's Avatar
That's the 112. 112 has 10 splines on the case while the 122 has 12. If all he wants is 'just a little more' than stock, then the 112 at 5psi will be fine.
Old Jan 6, 2011 | 07:03 PM
vortecyota's Avatar
Do you guys know from experience what max boost with a 2.6" pulley on a 112 on a stock cam 6.0 with oe manifolds with 2.5" y pipe to 3" facory style muffler. Could he see 7-8#s?
Thanks for the help guys!
Old Jan 6, 2011 | 07:06 PM
moregrip's Avatar
what a rush!
I saw 7lbs of boost on my stock LQ4 with a 112 and a 3.1 pulley
Old Jan 6, 2011 | 07:23 PM
vortecyota's Avatar
Wow, in that case I think a 112 will serve him well. Thanks for the replies. You guys are always very helpful!
Old Jan 6, 2011 | 07:29 PM
quicksilverado's Avatar
What's next Brint? I'll give you a ring tomorrow. Have a question for you.
Old Jan 6, 2011 | 07:44 PM
vortecyota's Avatar
I have a lot of good side work lined up if I can sqeeze the time out with the new bambino. First up is tonys truck. Gonna redo his twin 255s like the twin build on here a while back. Gonna be free but he really needs help. He is a little over 20k deep and hasent even got to drive it 5 days.
I know your opinion on the topic at hand but what if joe isn't too power hungry? I wish you could've seen the finished swap. By far my best work.
Old Jan 6, 2011 | 07:55 PM
terravast4's Avatar
I think a 112 with a 2.6 pulley your iat's will be through the roof....unless you are running meth.I have a 2.8 pulley and seeing about 11# of boost.
Old Jan 6, 2011 | 08:00 PM
vortecyota's Avatar
My man said he would want to gain 125 whp to make it worth while any more would be a plus.112, stock 6.0 =??? Max Rwhp gain
