MAF Help
Old May 13, 2008 | 10:05 PM
ntmd8tr's Avatar
Default MAF Help
I just had an experience that goes down im my record book for most redneck fix of the year. While preparing to run a ricer I boosted and had to back out of it to keep from hitting him. As soon as I backed out I heard a pop I got back in it and AFR went straight to 10.0 and truck tried to die. After checking all connections and found nothing wrong. I checked the impellar in the turbo and it still turns good. Boosted again truck quit running. Popped the hood and this time it was obvious.
The MAF was in two pieces and atleast an inch apart. Has anyone ever blown the maf in two and can it be fixed or is it totally lost.
Old May 13, 2008 | 10:11 PM
charcold-bowtie's Avatar
its been done. I know lpguy did it a few weeks ago. https://www.performancetrucks.net/fo...d.php?t=416376
Old May 14, 2008 | 01:32 PM
TrickTurbo's Avatar
Truck Sponsor
Yepper the maf is not designed for any stress or side loading.. We are looking into building this part and possibley adding to our kits....
Old May 14, 2008 | 03:17 PM
05stepside's Avatar
it happened to me with 2 different factory MAFs and we also tried to plastic weld one of them and added more plastic! well the same result happened. but i ended up going with a ls1 MAF and so far so good.
Old May 14, 2008 | 06:47 PM
hog's Avatar
hog
Amy performance loss going from the plastic 1 piece 85mm truck/Vette MAFS down to the 3 piece aluminum F-body/Vette 75mm MAFS??
peace
pauly
Old May 14, 2008 | 07:45 PM
blown3qtr's Avatar
blownchevy has a LPE 100mm MAF for sale in the classified section.
Old May 14, 2008 | 08:32 PM
ntmd8tr's Avatar
Ok I orderd the part from A & A corvette. I didn't have the money to get the LPE. I really want it but I just ordered a tranny, converter, different gauge set up, new oil pump, and a couple other things. The people at A & A gave me an explanation of why it happens. The cause is a fast acceleration with a faster decelleration. in other words get on the gas hard and suddenly let out and get on the breaks. it causes sudden massive increase in pressure and the MAF is the weakest link being a 2 piece set up. So for anyone interested, take this to heart and your MAF may last.
Old May 14, 2008 | 08:45 PM
TURBHOE's Avatar
do you have a BOV? if not it would seem this would fix the problem. i have one and with 10psi i haven't had a problem with the maf. although i am about to ditch it.
Old May 14, 2008 | 10:06 PM
ntmd8tr's Avatar
I do have a BOV but for some reason I don't think it opened b/c when it happened I didn't hear it open and I was also running 11lbs when It happened and I noticed the boost shot way up when I backed out. I have checked it and it seems to be working. I don't know if this was a freak accident or what but oh well It happened just like the sticker says.
Old May 15, 2008 | 08:24 PM
lpguy's Avatar
been there...https://www.performancetrucks.net/fo...ighlight=lpguy
Luckily i was on lunch break when it happened and i work at a machine shop.... its strong now...
