maf
Old Feb 18, 2008 | 02:22 PM
terravast4's Avatar
Default maf
any of you high boost guys have any problems with your MAF going out of range when pulleying down?
Old Feb 18, 2008 | 02:54 PM
dewmanshu's Avatar
Moderately Differentiated
a lot of people do, yep. Why what's wrong?
Old Feb 18, 2008 | 10:35 PM
terravast4's Avatar
MAF out of range causing bad idle sometimes. My tuner recommended a maf extender then re-tune. What are you guy's doing for this problem??
Old Feb 18, 2008 | 10:38 PM
thunder550's Avatar
High on diesel fumes
Get rid of the MAF and run a Speed Density tune.
Old Feb 18, 2008 | 10:43 PM
terravast4's Avatar
What does this entail and what are the benefits??
Old Feb 19, 2008 | 03:03 AM
Q8 6.0's Avatar
i have 2.75 pulley and i see 10PSI with no maf problems...have to rise the MAF fail frequency .in efilive its C2901.
Old Feb 19, 2008 | 07:32 AM
dewmanshu's Avatar
whoah whoah, slow down...your maf is out of range at idle? wtf. No reason to dump the maf if you are not blowing it at WOT imho. Speed density isn't necessary or right for every one who has maf issues. The maf is a good system, if you aren't maxing it.
Old Feb 19, 2008 | 08:34 AM
thunder550's Avatar
Hmmm yeah I missed the idle part. I agree with dewey, no need to go SD if it's not maxing at WOT.
Old Feb 19, 2008 | 02:38 PM
terravast4's Avatar
I think it is maxing at WOT and then getting confused at idle and kinda hunting around for proper air mixture.
Old Feb 19, 2008 | 03:07 PM
zippy's Avatar
With a 5.3L setup as he has he should just barely be maxing it, but not nearly bad enough to go speed density. If you are having problems like that it sounds like your tuning has some issues.
