maf
Old Feb 20, 2008 | 06:48 PM
  #21
leftcoast32's Avatar
FormerVendor
You can check the intake for a vacuum between the MAF and Throttle Body. If you dont have any vacuum between the MAF and Throttle Body then the MAF is not a restriction.
Old Feb 20, 2008 | 06:49 PM
  #22
FormerVendor
Originally Posted by terravast4
yeah, what do you recommend for bigger MAF?
I am using the Lingenfelter 100mm MAF and love it!!
Old Feb 20, 2008 | 06:53 PM
  #23
BlownChevy's Avatar
blownerator
25 Year Member
Call Lingenfelter and ask for Kevin. Let him know I sent you, if he does not take care of you....threaten him with the pictures of him and the goat.
Old Feb 20, 2008 | 06:56 PM
  #24
Sleeper04's Avatar
Originally Posted by BlownChevy
Bigger MAF would be my first choice.
Why not SD? It's more accurate, right?
Old Feb 20, 2008 | 06:57 PM
  #25
terravast4's Avatar
Anyone heard or used pro-m products. Looks like a good product.
  #26
BlownChevy's Avatar
blownerator
25 Year Member
In some peoples opinion....I prefer the reliability of a precision calibrated part.
Old Feb 20, 2008 | 07:34 PM
  #27
Sleeper04's Avatar
Fair enough......
Old Feb 20, 2008 | 08:06 PM
  #28
04Denali's Avatar
you must have a lot of pictures with people and goats, thats what you told me to say @ Granatelli
Old Feb 20, 2008 | 10:16 PM
  #29
BlownChevy's Avatar
blownerator
25 Year Member
LMAO.....yep
Old Feb 21, 2008 | 11:19 AM
  #30
dc_justin's Avatar
Hello Dave
P0101 is not caused by a max'd MAF. It's caused by a calibration problem as zippy said or possibly a dead cat converter, but you'd see MAJOR boost if that was the case. P0101 appears when the MAF measured and the VE calculated airflow is beyond the allowable threshold. My assumption would be that the tuner didn't quite bump up MAF rationality test/delta airflow table enough. This is dangerous to run the way you have it, as the moment that code trips, you revert back to speed density and are likely running extremely lean.
