LSX376 B15 W/TWINS 2002 silverado 4X4
Old Feb 23, 2020 | 09:48 PM
  #61
stacy moore's Avatar
The AC compressor lines might not clear the turbo with the Trick manifold so i might use the cheap up and forward facing headers and cast 90*​​​​​​​
Old Feb 23, 2020 | 09:52 PM
  #62
MikeGyver's Avatar
8 bolt holes on the crank for the flywheel. Is that normal on newer engines, or do you need a special flywheel?
Old Feb 24, 2020 | 06:43 AM
  #63
wretched73's Avatar
If you want to run a real exhaust, I'd use the trick kit.
I'd bet the Trick kit also holds more heat and has a higher velocity than those cheap headers, which should help you when driving on the street.
Old Feb 24, 2020 | 08:28 PM
  #64
Flexplate/Flywheel
The crank shaft flange for the flex plate or flywheel on the LSX454 and LSX376-B15 is the same as the 2009 Production
Cadillac CTS-V super charged LSA engine. It uses a quantity of eight 10 mm fasteners.
Old Feb 24, 2020 | 08:34 PM
  #65
I agree that the Trick kit is nicer but the cheep headers clear the Holley Mid Mount set-up. I'm still debating about switching to the truck style front drive or some 2010 Camaro exhaust manifolds and make a twin kit.
Old Jun 15, 2020 | 10:04 AM
  #66
dantheman1540's Avatar
Any updates? I want to see this thing in action!
The Fiddle
Dec 8, 2010 10:12 AM
350SS
Jul 18, 2008 09:27 AM
r8rs4lf
Dec 20, 2006 11:45 AM
04Z
Jul 25, 2005 10:26 PM
Stroker 1500
Mar 19, 2005 03:14 AM
