Benchmark that 383!
1999 350 roller block
.030" over
SCAT 3.75" cast steel crank
KB dished pistons
Lunati Voodoo 60120:
-Advertised Duration (Int/Exh): 262/270
-Duration @ .050 (Int/Exh): 211/219
-Gross Valve Lift (Int/Exh): .507/.515
-LSA/ICL: 112/106
Estimated 9.6:1 compression ratio
Comp 918's & 787's
Comp 1.52 ratio rocker arms
Vortec heads with 3 angle valve job and a little bowl work, nothing more.
....running on stock Vortec 350 exhaust with catback.
What do you guys believe this engine is making now, and what do you think it would make with some Pacesetter longtubes and 2.5" duals?
.030" over
KB dished pistons
-LSA/ICL: 112/106
Comp 918's & 787's
I would say its in 365 hp area.. Nothing spectacular, but prob a good running mouse. The cam is kinda on the small side.. What intake setup you running?? carb'd TB injection, efi?? If it is carbed is it single or dual plane intake??
What was the comp on that 338 you had that was making 500 hp??? and high high you winde it up??
No, it would be the SFI system with the plastic intake. Spider style injector. Between the fuel system, and the stock exhaust, I wouldn't put it much over 325 hp. It's really choked down.
i had a 338 similar to it and made around 500 ish
They make a mini injector upgrade for that, but won't get you much more hp if any, due to the mani set up
