LS2 90mm/04 TAC Module Teaser
Old Apr 29, 2007 | 09:56 PM
  #81
2004SSS's Avatar
im so pissed i got mine and now i dont know where the hell i put it. so looks like im going to buy another.
Old Apr 29, 2007 | 10:00 PM
  #82
04Denali's Avatar
To the back of the line
Hows you truck coming along?
Old Apr 30, 2007 | 09:18 AM
  #83
SSThunder03's Avatar
Originally Posted by DrX
Sorry, there aren't. But there will be a bunch when they are. Supply issues. I was told that my material was finally shipping over a week ago. Then I get an email on Thursday asking how I want it shipped because it can't go the way I wanted?? Still waiting to hear back on that. Not much better luck with the other supplier that I ordered from simultaneously. Researching alternatives while I am waiting because this is getting ridiculous.
Just want to make sure I'm on your list.
Old Apr 30, 2007 | 11:53 AM
  #84
dhpro's Avatar
OK...so I just heard about this and I'm a little confused. First pls add me to the list...CAN I JUMP TO THE FRONT SO I CAN GET MY 370/MP122 RUNNING? I bot the 90mm kit from WCCH and am using their J-Tube & TB. Richard told me about the flap issue. I assume I'll need this fix? What does Maggie put on their MP122 kits...do they have the same issue?
Old Apr 30, 2007 | 12:40 PM
  #85
cyazo6's Avatar
Can you jump to the front to get yours running! I want mine before I go to get it dyno tuned! You will need to get this fix inorder to get the throtle blade to open 100%. You should of already gotten a 2002 TAC module and harness adapter inorder to use the 90mm. When you recive this harness adapter from DrX you will reuse your stock TAC and remove the other one. All the 90mm guys have this issue,Maggie or not.
Old Apr 30, 2007 | 12:52 PM
  #86
TurboGibbs's Avatar
LOL! Some have pre-paid some time back that will be at the front of the list.
Old Apr 30, 2007 | 01:16 PM
  #87
DrX's Avatar
DrX
You are now.
Old Apr 30, 2007 | 01:55 PM
  #88
dhpro's Avatar
OK...spent some time on the phone with Maggie, and they're telling me the engineers say its a simple MAP issue. As I'm only just now aware of this and still coming up to speed that sounds as reasonable as anything else. They say that the controller in the TAC/PCM program reads too much air/airflow and shuts the throttle causing the motor to puke. If thats the case, then once I plug in my NELSON tune with appropriate MAPing and specific parts spec, this whole thing shudn't be a prob... R/
**Either way - PLS MAKE SURE I'M ON THE LIST**
Old Apr 30, 2007 | 01:57 PM
  #89
dhpro's Avatar
ITS ALWAYS WORTH A TRY!
Old Apr 30, 2007 | 04:38 PM
  #90
supersub's Avatar
You will have to swap back to your OE TAC module. I have had some issues with the engine loading up similar to what you describe after installing the Radix. Don't recall if it was there prior to the 90mm install or not. I had dealt with it in the tune(TCC/shift/kickdown tables).
Throttle position data is a significant factor in engine/transmision management, so incorrect data can result in some undesirable behavior.
thanks for the tip.mine clearly started after the 90 mm install,will look into it...and dont forget add me to the list also,thanks.
